Members Lasse Posted August 3, 2022 Members Report Posted August 3, 2022 Help finding 135x16 200 Hi y’all! I am trying to find 135x16 needles in size nm 25/200 and 24/180, with the LR point. It feels like I have been through the whole internet only to find 180 as a “special order” at Schmetz, and only for us citizens, the 200 seems impossible to find - maybe there aren’t any? Do you have any ideas or do you know where I can find some? I am in Sweden so buying the needles from the same store/place would be best cause Of shipping but I am getting frustrated and anything will do as this point. Many thanks in advance! Quote
Members Constabulary Posted August 3, 2022 Members Report Posted August 3, 2022 What machine are you using that you need such a big needle size in 135x16? Are you sure the machine can handle the thread thickness you need for a 180 or 200 needle? Anyway - as an alternative needle try to locate 134-35 needles with leather tip - same shaft size but just s a bit shorter than 135x16. Only thing you have to do is lowering the needle bar. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Moderator Wizcrafts Posted August 3, 2022 Moderator Report Posted August 3, 2022 Check out Gross-Beckert and Organ brand needle suppliers on Ebay. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Lasse Posted August 3, 2022 Author Members Report Posted August 3, 2022 6 hours ago, Constabulary said: What machine are you using that you need such a big needle size in 135x16? Are you sure the machine can handle the thread thickness you need for a 180 or 200 needle? Anyway - as an alternative needle try to locate 134-35 needles with leather tip - same shaft size but just s a bit shorter than 135x16. Only thing you have to do is lowering the needle bar. Hi! I am using a Seiko LCW-8BL, the machine should be able to handle it I have an Pfaff 335 with the 134-35 system so I might use them if I can’t anyones in the 135X16 system. Thank you for your help! Quote
Members Lasse Posted August 3, 2022 Author Members Report Posted August 3, 2022 On 8/3/2022 at 12:46 PM, Wizcrafts said: Check out Gross-Beckert and Organ brand needle suppliers on Ebay. There is nothing on the Groz-Beckerts website, I’ve looked before. And I can’t find the any of the sellers on eBay, can you link something? Quote
Moderator Wizcrafts Posted August 3, 2022 Moderator Report Posted August 3, 2022 20 minutes ago, Lasse said: There is nothing on the Groz-Beckerts website, I’ve looked before. And I can’t find the any of the sellers on eBay, can you link something? I searched for a while and this is the best source I can come up with at this time. https://sew-europe.com/schmetz.htm The list Schmetz and Gross Beckert on the home page. I hope this helps. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Lasse Posted August 3, 2022 Author Members Report Posted August 3, 2022 23 minutes ago, Wizcrafts said: I searched for a while and this is the best source I can come up with at this time. https://sew-europe.com/schmetz.htm The list Schmetz and Gross Beckert on the home page. I hope this helps. Nothing there either :/ Dimond point I have found in 180 and 200. But that’s not what I am looking fore. Quote
Moderator Wizcrafts Posted August 4, 2022 Moderator Report Posted August 4, 2022 1 hour ago, Lasse said: Nothing there either :/ Dimond point I have found in 180 and 200. But that’s not what I am looking fore. Do you want an inline S point, or some slanted chisel point? Schmetz makes the S point in system 134-35. I have a pack I use once in a while on my Singer walking foot machines. My machines are timed so that I can use these slightly shorter needles and not skip stitches, but only on one direction machines. If your machine has reverse you might want to lower the needle bar 1/2 mm or so to put the eye at the same position as the system 135x16 needles. Machines with reverse are more finicky when it comes to timing in both directions. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members cynthiab Posted August 4, 2022 Members Report Posted August 4, 2022 Look at this add on Ebay. Good price even with the shipping -- SCHMETZ:328D/TRI triangular point 135x16/DPx16D,Nm:200/25 Sewing machine Needles or look at this one 135x16TRI Industrial Sewing Machine Needles-Sz16,18,19,20,21,22,24,25-Box of 100 here is another SCHMETZ:328D/TRI triangular point 135x16/DPx16D,Nm:200/25 Sewing machine Needles Just copy and past the above titles into ebay and search Quote
Members Lasse Posted August 4, 2022 Author Members Report Posted August 4, 2022 19 hours ago, Wizcrafts said: Do you want an inline S point, or some slanted chisel point? Schmetz makes the S point in system 134-35. I have a pack I use once in a while on my Singer walking foot machines. My machines are timed so that I can use these slightly shorter needles and not skip stitches, but only on one direction machines. If your machine has reverse you might want to lower the needle bar 1/2 mm or so to put the eye at the same position as the system 135x16 needles. Machines with reverse are more finicky when it comes to timing in both directions. Really interesting reading and a ton of help. I have a few other points on needles but the LR is my favorite 3 hours ago, cynthiab said: Look at this add on Ebay. Good price even with the shipping -- SCHMETZ:328D/TRI triangular point 135x16/DPx16D,Nm:200/25 Sewing machine Needles or look at this one 135x16TRI Industrial Sewing Machine Needles-Sz16,18,19,20,21,22,24,25-Box of 100 here is another SCHMETZ:328D/TRI triangular point 135x16/DPx16D,Nm:200/25 Sewing machine Needles Just copy and past the above titles into ebay and search Great stuff but that’s not the point I am looking for. The LR point is what I need Quote
