12 minutes ago, AlamoJoe2002 said:
Brindal,
I use an older Osborne Draw Gauge that is shaped like a gun so you can wrap your trigger finger around for better control. I also have a non-typical 6" bar (typical is 4") that I cross my arm over the top of the draw gauge and grip and pull with two arms and other hand using the 6" bar. I'm cutting 12-14 ounce leather side skirting and it takes a bit of power even when my blade is sharp enough to shave. I've learned to start the cut with a Stanley knife then set the blade into the starter cut and start pulling. Even with the sharpest blade I can't pull thru the skirting with out clamping the starting end down.
I have to read more on the proper angle of setting the blade into the draw gauge. You can find these on Ebay...and other sellers. Some tilt the blade forward and some tilt the blade to the rear.
Oh, the 6 inch Draw Gauge was US Military Issue. I have that in addition to a US Military Issue round knife. Both made by C.S. Osborne.
-Joe
Neat to learn about the military issue draw gauge.  This tutorial from Bruce Johnson helped me to up my game with a draw gauge.   https://brucejohnsonleather.com/index.php/download_file/6881/202/
TomE,
I got the Osborne Round Knife enscribed "VA Ortho" and the Military Issue Draw Gauge from Bruce Johnson. Long story short, I needed a good blade for the draw gauge and we got to talking. One thing led to another and I sent him a US Flag I wore on my uniform on a trip to Afghanistan. So...I jumped at the chance to get the military issued items. The VA Ortho inscribed knife is my favorite. -Joe
