Members DJDreher Posted August 23, 2022 Members Report Posted August 23, 2022 Hello, I've been hand stitching for a couple years. Generally small goods, bags, wallets, belts. Mostly veg tan. I just picked up a Cobra 26, and now I'm trying to translate my work, or at least have the machine start working for me. Or trying to find a outlet for patterns that are more geared towards hand sewing. I have done a lot of the Dieselpunkro patterns. Attached is one on my favorites, or go to. In my head I can machine sew everything until I get to the last seam around the bag. Then I need to hand stitch to match the machine stitch? Which may be hard to match... Other tote patterns I've seen have some pretty bulky seams, or seams pressed into the bag. I'm still practicing, been machine sewing some outside gussets. But is there a pattern resource out there geared to machine patterns, like Deiselpunkro? Or on the bag attached, if you were to machine sew it, would you approach it as I described above. Quote
RockyAussie Posted August 24, 2022 Report Posted August 24, 2022 5 hours ago, DJDreher said: In my head I can machine sew everything until I get to the last seam around the bag. Then I need to hand stitch to match the machine stitch? Which may be hard to match... What is stopping you using the machine for the top line? Are the handle attachments in the way? Move them down a little if that is the problem. You could shorten the handle part where it stitches on as well if needed. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members DJDreher Posted August 24, 2022 Author Members Report Posted August 24, 2022 It's the closure of the main bag that's the issue. The seam in red. Basically closing the circle. I did mock up a bunch of small gussets, outside corners to practice on the machine. Going to be limits there, and also just me needing to keep practicing on it, Capture.pdf Quote
toxo Posted August 24, 2022 Report Posted August 24, 2022 2 hours ago, DJDreher said: It's the closure of the main bag that's the issue. The seam in red. Basically closing the circle. I did mock up a bunch of small gussets, outside corners to practice on the machine. Going to be limits there, and also just me needing to keep practicing on it, Capture.pdf 30.03 kB · 2 downloads Do those seams first with the bag inside out, then the bottom, then the top line. Quote
