Members Romey Posted November 11, 2007 Members Report Posted November 11, 2007 Bill , you mention using the vaccum for wood, do you happen to be stabilizine wood under vaccum? Quote Romey Cowboy inc highcountryknives
Members Skipknives Posted November 11, 2007 Members Report Posted November 11, 2007 Romey I have tryed to stabilize using a vacuum and kurrs jars that will hold the vacuum for weeks. I was using "spur-resens" because of the very thin viscosity and mixed a dye agent into it so i could map the progress. after a week under 25inches of vacuum i only got 1/16" inch of penatration (except at faults/checks) it would pull the air out of the wood in about an hour (no more bubbling). not much sucses. I am trying to get a pressure chamber made from a hydrolic cylinder that will hold 5,000 + PSI (safely) and will do more tests. Quote Skip Slocum Phoenix Arizona http://skpslocum.googlepages.com/home
Members Romey Posted November 23, 2007 Members Report Posted November 23, 2007 I built a really heavy duty stablizing unit a few years ago that would take up to 6000 psi, ofcourse a three hundred gallon air compressor would only push it to about 120PSI and the vaccum part of it was a 2 piston suction run my a 2 horse motor. It would get up to 29 inches and then hold as 28. Great stablizer. the issue was the material. I exsperimented with everything except what K and G and the other stabilizing pro , that stuff is 100$ a gallon IF you can get it. But i tried everything else readily available from Minwax to pentacrel and non of it worked every good as the stabilizing matrix. In the end the hours i put into that unit, hours and money I put into using it and not being happy with it i realized i was saving money buying the block from KandG or where ever, professionally stabilize. Just my 2 cents. Its a really neat machine i bit, and just sits in a corner now... Quote Romey Cowboy inc highcountryknives
