Members AlamoJoe2002 Posted September 24, 2022 Members Report Posted September 24, 2022 I'm focused on my edge work. I'm now using refillable Montana 15mm markers: https://www.amazon.com/Montana-Acrylic-Empty-Marker-045475/dp/B006ZM19P2/ref=sr_1_5?crid=7G3KERUURFSE&keywords=montana+refillable+marker&qid=1664026879&sprefix=montana+refillable+marker%2Caps%2C339&sr=8-5 I use these to apply water, liquid saddle soap, full strength Flebings Dye and now am considering using a refillable marker for applying resolene in my last step of edge work on 12-14 ounce belts. I use a dremmel burnishing wheel in between applications to smooth the edge. I'm not at the glass stage with the natural, no dyed edges yet. I burnish with the dremmel then finish the pass with denim. Do you have any good or bad comments on using the marker to apply resolene? I'm using full strength. Do I dilute it or is a simple full pass or two the way to go using full strength. Guidance to include failures requested...along with your successes. -Joe Quote
Members Dwight Posted September 24, 2022 Members Report Posted September 24, 2022 Resolene put on full strength will crack, break, peel, and go away. Dilute it to 50% is what I've done and have had no problems since. May God bless, Dwight Quote
