Members Farmfield Posted October 27, 2022 Members Report Posted October 27, 2022 (edited) Edit: Solved. It looks like I'm missing some kinda rubber spacer thingie on the back. I need to understand the stitch length adjuster on the Claes patcher. On the one I have here I can only conclude it doesn't work, but I haven't been able to figure out how it works, mechanically, and it's hard to fix what I don't understand. Edited October 27, 2022 by Farmfield Quote
Moderator Wizcrafts Posted October 28, 2022 Moderator Report Posted October 28, 2022 Our member @shoepatcher can probably help you. He rebuilds Claes, Adler and Singer patchers here in Michigan, USA. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Constabulary Posted October 28, 2022 Members Report Posted October 28, 2022 What CLAES model do you have? From the 200 / RPX onward there is a leather (or later) plastic block under the stitch length adjuster, make sure it is is present. If not feeding make sure the "Transportkeil" (see parts list) is not popped out of place. It should "hang" in the rim of the needle bar bushing in which the needle bar is going up and down in. Just notice the the EDIT so forget it. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Farmfield Posted October 28, 2022 Author Members Report Posted October 28, 2022 On 10/28/2022 at 12:11 AM, Constabulary said: What CLAES model do you have? From the 200 / RPX onward there is a leather (or later) plastic block under the stitch length adjuster, make sure it is is present. If not feeding make sure the "Transportkeil" (see parts list) is not poped out of place. It should "hang" in the rim of the needle bar bushing in which the needle bar is going up and down in. Just notice the the EDIT so forget it. Yeah, noticed the block was missing, made one a so now it works. :D Quote
Members shoepatcher Posted October 28, 2022 Members Report Posted October 28, 2022 pics of the machine? glenn Quote
Members Farmfield Posted October 28, 2022 Author Members Report Posted October 28, 2022 3 minutes ago, shoepatcher said: pics of the machine? glenn Here: https://photos.app.goo.gl/69e1qLTaMdGQ444J8 And I made a leather block for the stitch adjuster, though not in these pictures. Only thing is max stitch length seems to be 5mm while the stitch length adjuster is between 0 and 10mm. Not sure why it maxes out at 5 - even with the leather block removed, thus allowing the accentric thingie to its lowest position... Quote
Members Constabulary Posted October 28, 2022 Members Report Posted October 28, 2022 (edited) 10mm is not the stitch length. Rather consider it just as a scale. From my experience the model 200 (which you have) makes 6mm Stitches at max. If you need a manual in English, I once translated one from German language and edited it a little bit (original source was an RPX manual but the 200 class are very similar). Send me a PM if interested. Edited October 28, 2022 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Farmfield Posted October 28, 2022 Author Members Report Posted October 28, 2022 (edited) 7 minutes ago, Constabulary said: 10mm is not the stitch length. Rather consider it just as a scale. From my experience the model 200 (which you have) makes 6mm Stitches at max. Sounds about what I get, so it is what it is, then. Any ideas where to get bobbins and/or bobbin case for this model? Else I got some milling, lathe work and soldering ahead of me... Edited October 28, 2022 by Farmfield Quote
Members Constabulary Posted October 28, 2022 Members Report Posted October 28, 2022 (edited) do you have a 200-1, 200-2 or 200-3 (lager prefix = lager hook) CLAES is still making the bobbins so you should be able to get them from shoe machine dealers or other sewing machine dealers. If not check with CLAES, I once visited the plant and bought some spare parts straight from them. Nice folks, really! But shipping from Germany to to Sweden probably is a deal killer. https://www.cl-maschinenbau.com/de/leistungen/naehmaschinen.html Some (not all) parts from the latest 8346 are still the same as for the 200. When you check the 8346parts list all parts with 200 prefix are still the same. However the new hooks could be slightly different (thats what they told me). Edited October 28, 2022 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Farmfield Posted October 28, 2022 Author Members Report Posted October 28, 2022 3 minutes ago, Constabulary said: do you have a 200-1, 200-2 or 200-3 (lager prefix = lager hook) CLAES is still making the bobbins so you should be able to get them from shoe machine dealers or other sewing machine dealers. if not check with CLAES, I once visited the plant and bought some spare straight from them. Nice folks, really! But shipping from Germany to to Sweden probably is a deal killer. No clue on the subclass, I haven't found any markings on it, but it's one of the smallest bobbins I ever seen, though a bit taller than the Singer 29 ones, I think. As for shipping, this machine was imported from Germany through Poland on a pallet with 3 other leather machines, haha, so shipping is a non issue. It was bought for resale. Quote
