What weight maul or hammer would you recommend for punching belt ends and oblon punches . I saw some one recommends a 3 pounder. Would that be too heavy? Any experience with Barry Ling Maul for this purpose? Thanks in advance for the wisdom and advice.
It depends on a few things
How sharp are your punches? Sharper punches or smaller punches and you can go lighter, -  a #3 is as much as I ever needed for anything and not very often.  About the only time I use a 3# is on rosette punches. They have a lot more linear edge than other punches and need a little more force.
What kind of supporting surface? something with a little flex will need more force than a solid supported surface. End grain stump or post, punching over a supporting leg of a work bench will be more solid with less force absorption than middle of a bench.
My punching setup was a piece of LDPE over a granite inspection plate on one bench or LDPE on a shoeing anvil.  The mass of either support pretty well negated any flex of whatever it sat on.
I sell a fair amount of mauls and mostly 2# or 2.5# for strap end and bag punches with the occasional 3# for the bigger punches or duller punches.
Barry King' mauls are nice with a handle shape for a good grip.
Bruce Johnson
Malachi 4:2
Excellent tip ! thank you. I just got a 55 lbs small cast iron anvil from Amazon and plan to use that for pounding.For this purpose and not for tooling, would it make sense to get a taper maul or should i stick with hammer ?
Metal hammers will wear the striking end of your punch fast. Rawhide mallets with replaceable inserts are good and some prefer those.  I like mauls and once we get into that tree then I like tapered mauls best.
Bruce Johnson
Malachi 4:2
  • 3 weeks later...
I use a 1 3/4 in belt slot punch from weaver. I recently found a "wood is good" maul from a local "vintage shop" for  $20. Probably not that old, I can still find the website. It's one of the larger mauls, works very well, but not as expensive as BK at all!
Not so retired RN. Living on the Washington Peninsula.
