Some years ago I was in about the same situation when I was hunting for a Singer 34K NB:
https://leatherworker.net/forum/topic/66729-singer-needle-bar-i-could-use-some-help/
The REX here is a clone of the Singer 16-188. NB in the Class 16-188 parts list is # 4264 so this should work:
https://www.ebay.com/itm/292096957975
You may find it from other dealers too.
EDIT:
And don`t forget the needle bar clamp.
I would also order some needle plate screws and 1 or 2 new check springs or a complete tension unit, 1 or 2 bobbin cases and a new CB hook just to have spares on hand when needed. The parts are not really expensive.
Edited by Constabulary
I've seen  so many restores on this site, just proves nothing is impossible:yes:
I can't help but notice the remains of what looks like a sump gasket sitting on the bed, and a tube of gasket sealer .
Should look quite good when its finished :specool:
HS
' I have a very gweat friend in Wome called Biggus Dickus,
He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '  :rofl:
