Do you know of suppliers of very long upholstery needles longer than 0.5 m or 20"?
For some odd experimental project I like to try to use such a needle. It needs to have a needle eye and one sharp point end. I guess, that it needs to be at least 2 mm in diameter and made of a piano-wire kind of steel.
Do you know of suppliers of such long needles in North America and in Europe?
I found this supplier of a 24" needle in Arizona:
https://homesewingdepot.com/products/upholstery-needle-24-11-gauge?variant=32770271685
What size is a 11 gauge needle?
  • 1 year later...
C.S. Osborne makes some large needles. For example:
STRAIGHT SINGLE ROUND POINT NEEDLE – HEAVY #554.
Lengths are from 6 inch to 24 inch, with varying diameters.
The 25 inch needle is a gauge 11, which is 2.95 mm diameter.
Here’s a website.
osborneleathertools.com/product/straight-single-round-point-needle-heavy/”
Osborne uses the “British Standard Wire Gauge”.
Maybe the upholstery needle supplier you reference does also.
Refer to this Wikipedia article.
en.wikipedia.org/wiki/Standard_wire_gauge”
Here’s another reference.
www.thethreadexchange.com/miva/merchant.mvc?Screen=CTGY&Category_Code=Hand-Sewing-Needle-Information”
Thank you for the moved post and answer :)
