CFM Frodo Posted November 29, 2022 CFM Report Posted November 29, 2022 IMG_3658.MOV Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
CFM Frodo Posted November 29, 2022 Author CFM Report Posted November 29, 2022 Video is not uploading the service on my end is sketchie. We pipe in the sunshine and the pipe does not leave room for a web wire out here in BF finally received bobbins ad threaded them up. I see a learning curve coming up needle intermittently catches the bobbin and misses stitches. Sounds like I need to adjust, the bobbin spring is set so the bobbin dangles on the thread that is held by my fingers then will play out the thread when I rapidly move my wrist, kinda like when you jiggle a hook in front of a fish top thread tension is the same I have not adjusted For the correct needle height. Is the trick of bumping your finger tip with the needle under the shuttle arm the same on the singer as it is on a chichi patcher? I will upload t YouTube then to her tuomorrow thanks guys Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
CFM Frodo Posted November 29, 2022 Author CFM Report Posted November 29, 2022 Couple hours later i tore apart the top tension disk assemply and gave it a good cleaning plus etc. tightened the discs This is the top thread, bottom tension needs tightened? Bottom thread photo If I am reading this correctly, top tension is ok bobbin tension needs to be tightened? side note, this machine is freaking cool Do not laugh at me guys, I am learning Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
CFM Frodo Posted November 29, 2022 Author CFM Report Posted November 29, 2022 Skipping?what causes this ? Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
CowboyBob Posted November 29, 2022 Report Posted November 29, 2022 Wrong needle,needle threaded wrong, needle in wrong or you need to re-time the shuttle. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
