Hello,
can somebody Can you identify this Singer 29K model? (Serial number plate has been lost).
The one in background (also the front one is interesting too)
Thanks,
Janis311168315_6215516408508926_4004756835586313665_n-2.thumb.jpg.d2fa9e3a5c45434985415643e5b86658.jpg
Long arm.      Need to see a better pic of the end of horn.  Either 29K55, 56, 60, 62, 72, 73.   The squarish of the horn leads me to say 60.62, 72, 73.  Bobbin size will narrow it down more.
glenn
To the best of my knowledge every Singer had their serial numbers molded in the frame. Like shoepatcher has noted the one in the background is a long arm Singer 29K ???. The location of the serial numbers can be found on the flat surface of the body just below where the model badge and company emblem were originally. Once you get those numbers you can go to ISMACS International ( https://ismacs.net/singer_sewing_machine_company/singer_dating_by_serial_number.html ) find the serial number and from that you can find the model model number and the year it was made.
You can also do the same for the machine in the foreground since it is also a Singer.
kgg
I would guess 29K33 small bobbin (has a leaf spring on the rear - notice adjustment screw for the spring) or a 29K30 with large bobbin (could be cause it looks a little wider around the needle plate)  - but all just -guessing.
