CFM Frodo Posted January 9, 2023 CFM Report Posted January 9, 2023 My servo pulley is 2” the jack shaft has a 5” pulley on one side with no pulley on the other the machine head has a 3” pulley on it if I set the pulleys up in this order servo2” 5” jack shaft X size jack shaft To 3” head pulley would X pulley need to be 2”? if the slave pulley (x) is larger than the master (5) would that defeat the of rpm? Quote
kgg Posted January 9, 2023 Report Posted January 9, 2023 52 minutes ago, Frodo said: My servo pulley is 2” the jack shaft has a 5” pulley on one side with no pulley on the other the machine head has a 3” pulley on it if I set the pulleys up in this order servo2” 5” jack shaft X size jack shaft To 3” head pulley would X pulley need to be 2”? if the slave pulley (x) is larger than the master (5) would that defeat the of rpm? With the arrangement of the set 1 pulley = 2" (servo motor) with a large pulley = 5" and set 2 pulley = 2" with the machine pulley = 3" (handwheel) then: 1. servo motor at 100 rpm the handwheel will turn at 27 rpm's 2. the center of the pulley on the servo motor to the center of the reducer pulley (2" x 5") should be 10" 3. the center of the reducer pulley (2" x 5") to the center of the 3" handwheel should be 14" 4. the reduction ratio is 1:3.75 at the handwheel kgg Quote
CFM chuck123wapati Posted January 9, 2023 CFM Report Posted January 9, 2023 1 hour ago, Frodo said: My servo pulley is 2” the jack shaft has a 5” pulley on one side with no pulley on the other the machine head has a 3” pulley on it if I set the pulleys up in this order servo2” 5” jack shaft X size jack shaft To 3” head pulley would X pulley need to be 2”? if the slave pulley (x) is larger than the master (5) would that defeat the of rpm? 2 to 5 then 5 to 2 would negate it completely 3 to 2 would negate it somewhat. what is your maximum intended output rpm? Quote
kgg Posted January 9, 2023 Report Posted January 9, 2023 (edited) 1 hour ago, Frodo said: My servo pulley is 2” 9 minutes ago, chuck123wapati said: 2 to 5 then 5 to 2 would negate it completely 3 to 2 would negate it somewhat. I forgot to add the calculator I used for your arrangement so you can decide what arrangement would work with your setup: ( https://www.blocklayer.com/pulley-belteng ) kgg Edited January 9, 2023 by kgg Quote
CFM chuck123wapati Posted January 9, 2023 CFM Report Posted January 9, 2023 2 minutes ago, kgg said: I forgot to add the calulator I used for your arrangement so you can decide what arrangement would with your setup: ( https://www.blocklayer.com/pulley-belteng ) kgg sweet calculator !!!!! sure takes out the brain work lol. Thanks, I will be saving that. Quote
kgg Posted January 9, 2023 Report Posted January 9, 2023 5 minutes ago, chuck123wapati said: sweet calculator !!!!! sure takes out the brain work lol. Thanks, I will be saving that. Saves a lot of time and figuring. I came across this calculator when I had to change the pulley system on my wood furnace a few years back. kgg Quote
CFM Frodo Posted January 10, 2023 Author CFM Report Posted January 10, 2023 Thank you kgg could not get back yesterday I was at the hospital giving birth to kidney stones Quote
kgg Posted January 10, 2023 Report Posted January 10, 2023 4 hours ago, Frodo said: I was at the hospital giving birth to kidney stones That is never good, I know first hand that birthing process. Take it easy for few days. kgg Quote
CFM Frodo Posted January 10, 2023 Author CFM Report Posted January 10, 2023 2 hours ago, kgg said: That is never good, I know first hand that birthing process. Take it easy for few days. kgg looks like according to the calculations 2”” then a 6”” next to an 8”” that goes to a 6” and the machine is 3” Quote
kgg Posted January 10, 2023 Report Posted January 10, 2023 I think you were brewing them for a while and at least they were the smooth ones not the star shaped ones. 2 hours ago, Frodo said: looks like according to the calculations The main thing is how slow do you want to go and what you are going to set the rpm of the servo motor too. So you will have to play with the pulley sizes on the calculator as well as the rpm of the servo motor. kgg Quote
CFM Frodo Posted January 11, 2023 Author CFM Report Posted January 11, 2023 Servo set at 350 I want to go very slow around corners and such as that 30 per minute or less Quote
kgg Posted January 11, 2023 Report Posted January 11, 2023 29 minutes ago, Frodo said: Servo set at 350 I want to go very slow around corners and such as that 30 per minute or less The constants you have as I understand them: 1. the size of the motor pulley for set 1 pulley is 2" 2. the size of the handwheel for set 2 pulleys and you want to use a 5" large pulley 3. the speed of the motor max to be 350 4. the rpm of the set 2 pulley to be 30 when sewing around corners What I would suggest according to the calculator to get 30 rpm is 1. set 1 small pulley 2" (motor pulley) with a 5" large pulley and set 2 would be a 1.5 small pulley alongside the 5" on the same shaft giving the handwheel a speed of 30 rpm with 150 rpm on the motor When you increase your motor speed up to 350 rpm (max setting) by fully depressing the foot pedal the handwheel rpm would be 70. The pulley alongside the 5" pulley has to be smaller then the handwheel pulley. kgg Quote
