You are welcome, I'm glad you like it :)
  • 2 weeks later...
I have watched several videos of the folks in India making a living sorting thru the dumps, collecting trash and recycling it into real actual usable products.
  • 6 months later...
Dirt track racing tires have fiber reinforcement but no steel. Folks who make recylced tire door mats use them when the racers are through with them.
On 1/11/2023 at 4:59 AM, Klara said:
Or even just his blades. I'm pretty sure that the ones I have don't cut so well. The other question I had was about the tires: Aren't our tires reinforced with some textile (or wire?) material? Those ones look like pure rubber. I might have to talk to my car mechanic...
I like videos like this. Shows that fancy expensive tools don't always mean anything. Cheap home brew tools in skilled hands.
Are you genuinely asking what blades he might be using?(sorry i couldn't tell if your asking what he was using was sarcasm or not lol)  Try a few different brands of utility knife blades. Try brand name and cheap ones, there's different steel as well. Razor blades as well for the groover and some whatever the heck handle and a hose clamp with a knob attached.
The rubber looks like retread material. Metal beads are only on side walls generally. Not all retread has any canvas/material layering.
So a fresh sharp utility knife, even a dollar store one, would cut like butter, initially. Lasting sharpness is another thing.
Can buy 1/2" rubber stall mats at farm stores.  They won't have tire tread but typically one side is textured and the other might have shallow grooves (to channel pee).  They're not hard to cut, at least in a straight line, using a sharp utility knife.  I usually put a scrap of plywood under the mat next to the cut line so I can bend the rubber slightly and remove pressure/friction from the blade.
Yes, I was seriously asking because I am generally unhappy with utility knife blades...
I suppose it depends on the material you work with, if heavier leathers or ultra thin, more specialized dedicated knives would be the route.  With the leather type and weight i work I've been happy with brand name utility knives and blades for 10 years, but there are better ways. Head knives of course, like many of the experienced folks here use, i just haven't gotten around to practicing with it, and being so comfortable with utility. There's also those knives like the Vergez Blanchard L'Indispensable Brass Knife and many other styles and types, cobbler knives etc that many here use. Someone with more knife experience could offer some great advice if you made a post i'm sure. Searching for the perfect knife can be a rabbit hole!
I routinely strop my utility knife blades (and even the cheap snap off blades). Gets them sharper and last longer.  I will strop even before 1st use.
I have enough knives I am happy enough with (but no boxcutters), and if I am unhappy, it's because I haven't sharpened them well enough. But cutting through tires like that is in a different league,  IMHO.
