I have a Cobra 26 machine , I was winding a bobbin and did'nt remove the upper thread, the machine jamed,  I have not been able to remove the bobbin carier,need help, If i remove the screw, for the thread seperator i can move machine complete revelotions but the bobbin case moves with hook.
thanks in advance
Mack
Just put some oil all the way around the hook,take your belt off,turn the machine towards you as far as it will go & then push the wheel backwards as fast & hard as you can.It might take a few tries BUT it's usually impossible to get those screws out when it's jammed up.
Thank You I will give that a try.
looks like ihave broken a small piece of the carrier, will probably need to replace that, do you carry parts?
