Members jrk65 Posted March 12, 2023 Author Members Report Posted March 12, 2023 Sorry for the poor description in my post. This machine has the Ferdco smooth plate with the needle guide in place of a feed dog. It is not loose. There is no slop in the linkages, or excessive wear in the needle bar. This machine has very few hours of use. Don't wear your church clothes around my machine as there is more than plenty of oil on the mentioned knuckles. Old timers used to tell me grease is cheap. Now I'm and old timer, so is lube oil. I have adjusted the needle and walking foot timing, adjusted the presser foot, and that seems to have fixed the problem. I'm going to stick my neck out here: Timing, Timing, Timing! Thread size, thread brand, nylon/poly/bonded, needle size, to some extent tension, variation in thread path from spool to take up spring. While important, adjusting, changing these things are little more than tiny bandaids, if the machine is not totally in time! Mine was not. Operator error. DIY mechanic error. I have learned many things about these minor adjustments, that will help fine tune my stitching in the future. It seems that these adjustments are what takes a machine that "sews" and makes it in to a machine that "sews really well". That is my goal. Just my opinion. Thanks for your comments/suggestions, they all open up avenues for working through a problem. Quote
Members Patrick1 Posted March 14, 2023 Members Report Posted March 14, 2023 @jrk65 should invest in a XTREME #25 NARROW FEED DOG WITH FLAT STAINLESS PLATE at heprecision.com for your Ferdco. Had a customer purchase one for his Ferdco last week with the same set-up as yours and similar issues. Don't have to stick my neck out here, feed dog, feed dog, feed dog! As @RockyAussie was saying about the oil, it's extremely important. Had another customer who purchased a brand spanking new CB 4500 with feeding issues. Had him pull the side plate, put some oil the presser and center foot bars and everything in between and now it runs as it should. Quote
kgg Posted March 14, 2023 Report Posted March 14, 2023 1 hour ago, Patrick1 said: Had another customer who purchased a brand spanking new CB 4500 with feeding issues. Had him pull the side plate, put some oil the presser and center foot bars and everything in between and now it runs as it should. Another place people forget too oil is the other end of the bottom shaft that is accessed by opening the two round cover plates on the main part of the machine. Like RockyAussie said: On 3/12/2023 at 10:32 AM, RockyAussie said: Simple ...if it turns/revolves it should be oiled. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
