Members Pappys Leather Posted March 24, 2023 Members Report Posted March 24, 2023 (edited) Looking for the measurements for making 22cal bullet loops. I found information all several other sizes. Is 32 cal larger or same size? Edited March 24, 2023 by Northmount Removed a couple hundred lines of white space Quote
Members Dwight Posted March 24, 2023 Members Report Posted March 24, 2023 32 caliber is twice the size of .22 long rifles. You don't need measurements for making bullet loops . . . you punch a hole in your belt . . . an oval slot . . . pull a piece of leather thru the slot . . . around the bullet . . . then back thru the same slot . . . leather needs to be wet . . . use 3/4 oz . . . when it gets mostly dry . . . pull the bullet out and let it finish drying. Making bullet loops is very easy. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
