Hey Folks,
So I am so excited to be a new owner of a Cobra class 26 but I have two problems.
1. I cant solve a problem with having one loose stitch during projects.   I will adjust the tension and the knot is sitting in the middle and during a sewing run ill get one loose stitch almost every time?
2. The machine is in a terrible bind and making a squealing honking noise when sewing. The noise is still present when using the hand wheel with no thread loaded.   I eliminated the thread to eliminate potential tension issue but the machine is so tight and seems to be in a bind?   I've oiled heavily with some minor improvement.
The problem has been so bad that the great people at Leather Sewing Machine Co. have even spent hours on the phone with me.   They even had me making adjustments on the internal shaft from the wheel and inside shaft.  They facetime me to watch the machine and we made some adjustments to the bottom bobbin.  This seemed to have helped a tad but the machine feels to be under internal friction.    David at LMC customer service was the best I've ever experienced and he talked with me on the phone and email throughout the diagnosis.   He was so understanding and accommodating that he even sent me a new head this weekend; however , sadly the new head did the exact same thing????     The shipping box from UPS was pretty beaten up??  I don't know if shipping could be causing damage but both machines are under a bind somewhere.
 I have wanted one of these machines for years but I need anyone's help that may have experienced similar issues and fixes if possible. I'm so discouraged and exhausted I just want this beautiful machine to lay down a good stitch and not sound like squealing tank.     Maybe a bad run of machines or shipping damage?    Again, If you want a new sewing machine and not sure where to purchase?   PURCHASE FROM LEATHER SEWING COMPANY because what they say about amazing customer service is absolutely TRUE.    Hands down best service I've ever experienced and I owned a cowboy 3200 and Ryan was pretty dang great.   This is mechanical issue not a personal one for sure!
I am going to assume the drive belts to the motor in installed. I would remove the drive belt from the handwheel to the reducer pulley and see if the squealing disappears. If it does then you know the problem lies with the belts, reducer pulley or servo motor. If the squeaking still remains you know it is machine head related.
kgg
If you are already dealing with support from the dealer, we shouldn't interfere. But, KGG's suggestion to remove the belts is valid.  It may just be an overtightened belt, of which you have three. Or, the bearings could be bad on the motor and speed reducer.
Has LMC asked you to remove the bobbin case securing bracket and the bobbin case, to check for thread fragments? There could be thread stubs causing binding.
The fact that the new head is doing the same thing makes me suspect your belts/motor/speed reducer. Remove the belt from the machine and see if it turns freely and without the moaning sound.
Posted IMHO, by Wiz
Gentlemen thanks so much for your input.   Yes I have removed the belt and the moaning is still happening.   The attached video lets you see the internal mechanisms as the noise is occurring.   You can even feel the resistance in the head unit when sewing and manually using the wheel with or without the belt on?
My first head is starting to improve from the tapping of the shaft LMC had me try and multiple days of heaving oiling.   The second head is still moaning and seems to be under some sort of bind internally.
Yes this post is in no way meant to interfere with the good folks at LMC just looking for other suggestions and experience with solving the issues.   I sent the post during off hours with LMC.
Any suggestions on this loose stitch?    I have adjusted the tension where the knot is in the middle of my leather and I am still getting these loose stitches randomly?
I don't see an additional video attached. Which parts seem to be causing the problem?
I wouldn't make any adjustments just yet until you get the main problem sorted out first with LMC.
Please keep us updated.
kgg
Does the balance wheel rotate true, or wobbly? If it wobbles the main shaft may be bent.
You can try unscrewing the presser bar to see/hear if it makes a difference being out of the picture. If the binding disappears the bar may be bent, or binding in its top or bottom bushings.
If the presser bar isn't the culprit, maybe the needle bar is. Mark its position fully raised (with a Magic Marker, or tape), then loosen its screws and try rotating the wheel. It too goes through a bearing. Perhaps it is slightly bent.
Posted IMHO, by Wiz
Since oiling and tapping of the shaft has helped I would also ask LMC if instead of the normal machine oil if something like a good penetrating fluid or Synthetic transmission fluid or even diesel fuel would be another alternative combined with oiling. I don't use regular sewing machine oil in any of my own sewing machines. I find that a mixture of Synthetic transmission fluid and Synthetic oil works much better but I am willing to take the risks associated of going outside normal sewing machine oiling / lubrication recommendations. I often use diesel fuel to free up seize metal components.
You did mention that the boxes you received from UPS on the second machine was pretty damaged. Did you save the box as couple of photos of the box may help to determine was the damage caused by mishandling.
kgg
Ill try to rotate the wheel with out the belt off and check to see if it wobbles.   When sewing or turning the wheel you can feel how tight everything really is and the squeaking noise is present around that needle bar it seems?
I did save the box and took several pictures of the second head that arrived damaged.   LMC sending that new head was pretty amazing and I just knew I would be back up and sewing but cant believe two would be doing same thing?   The first head was on a crate with the stand wrapped up really well so the box  looked really good and protected from all the wrapping and stand.
I think wizcrafts may be onto something with an internal part bent or damaged.   Maybe there was a problem with a part during build process and both machines are suffering from it?
Ill try the presser bar this morning that would be an easy test.  The needle bar does seems to be the loudest and the oiling in that area did help some?
Sense the oiling did improve some of the problem ill ask LMC about using a different oil today.  Ive been on 24 hours shifts so today will be my first day back home with the machine.   Ill reach back out to them and see if we can get some more progress and keep everyone posted.
Thanks again for your responses I think both of you have given some really good suggestions and Ill have some focus today when working with LMC.
The loose stitch issue has also been present from the beginning and drives me crazy because I cant get rid of it with tension adjustments?
First of all, thank you for you service in the Fire Department.
Second: Once you get the machines working smoothly and reliably, we can talk about thread and needles you'll need to repair turnout gear. I've already done a couple and learned the requirements. It will not be the type of thread that shipped with the machine. This is a whole 'nuther topic.
Posted IMHO, by Wiz
Not to hijack this thread, but your comment about thread for heat resistant applications caught my eye...  About two years ago, shortly after I started my sewing "hobby" I got it in my head that it would be nice to make some oven mitts after I saw someone with neoprene mitts where the stitching had come open on one.  I offered to stitch them up, and at the time only having bonded poly thread, that's what I used.  (It was for a girlfriend.)  That got me doing a bit of research and thinking that it would be no big deal to get some neoprene and make mitts myself, I bought some thread from A&E specifically for heat resistant applications.  I can't remember exactly what it was called, but I think it was Anesafe.  I do remember that the one pound spool (idiot that I sometimes am) was frightfully expensive.  Then I found I really couldn't source the neoprene (at least not here in Canada) in the quantity, thickness and style I wanted, so I shelved the idea.  I should have sourced the neoprene before buying the expensive thread.  SIGH
I still have the thread though, and if I could find a reasonable source for neoprene I'd make some.  The mitts my friend had had a bit of a pebbled finish on the outside and the inside had a fabric coating.
If anyone could suggest a Canadian source for small quantities of similar neoprene I'd really appreciate it.  Ordering from the States, with minimum order quantities, becomes really expensive when you add the exchange rate, shipping and import duties and taxes.
Current machines: Janome HD3000 and Skyline S5, Consew 206RB-5, Singer Profinish serger, Techsew 2750 PRO, Sailrite LSZ-1 Premium, Consew DCS-S4 Skiver
