CFM Frodo Posted April 12, 2023 CFM Report Posted April 12, 2023 I have not seen this issue addressed anywhere here is my fix. If anyone has a different fix please post it your thread breaks in the middle of a run or your bobbin runs out. A backstitch in this area would look bad what I do is pull the thrread out of the leather for approx 2”. Then knot the 2 threads cut singe start a new stitch line by placing the needle in the holes already made, do not back stitch but tie the threads cut singe. no back stitch is showing on the top threads are tied/ singed on the back side Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
CFM Frodo Posted April 12, 2023 Author CFM Report Posted April 12, 2023 Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
Contributing Member Samalan Posted May 1, 2023 Contributing Member Report Posted May 1, 2023 On 4/12/2023 at 4:10 AM, Frodo said: the two holes in the center don't look too good I do just what you said but I don't make a knot just cross the two threads like your going to tie a knot then what I do is use a vainer tool and start right at the hole cut a small groove on opposite sides pull the thread tight and lay it in the grove with contact cement and I've never had a problem but I will say that second hole in the center looks awful. Quote
