Members gunfighter48 Posted February 13, 2008 Author Members Report Posted February 13, 2008 Great looking Belts John,stiching is perfect , What type of sewing machinedo you have. May i make a sugestion??? get yourself some better looking Buckles some with some heaft...I M H O P... I have a Neels Saddelry Model 5 machine (drop feed, cylinder bed). It does a good job, leaves a light imprint of the feed dogs on the back side of the belt but doesn't seem to be a problem with my customers. I'm still working on getting the presser foot tension set so that the marks are as light as possible and still feeds reliably. I hear you on the buckles, most of my customer prefer a plain buckle and I'm getting ready to order again so will try a different style with more heft. John Quote gunfighter48 A 45 may not expand but it will never be smaller than .45!! NRA Member PSLAC Member
Members Warren Posted February 13, 2008 Members Report Posted February 13, 2008 Sorry, I guess you answered my leather weight question while I was typing out my post. Thanks,Warren. Quote
Members gunfighter48 Posted February 13, 2008 Author Members Report Posted February 13, 2008 Sorry, I guess you answered my leather weight question while I was typing out my post. Thanks,Warren. Hi Warren, Belts usually run 1 to 1 1/2 in wide, with 1 1/2 in being the most popular width ( it will fit most jeans, docker style pants). The wider belt helps to prevent the belt from twisting outward when carrying a concealed weapon. This keeps the weapon pulled in tight to the body and that conceals it better. I personally like Inside the Waist Band holsters, I have never been spotted when carrying with that style holster. I skive the tongue and buckle ends to minimize the bulk and make them easier to buckle up. They are very stiff when new and will loosen a little with use. John Quote gunfighter48 A 45 may not expand but it will never be smaller than .45!! NRA Member PSLAC Member
Ambassador Luke Hatley Posted February 13, 2008 Ambassador Report Posted February 13, 2008 Hi Warren,Belts usually run 1 to 1 1/2 in wide, with 1 1/2 in being the most popular width ( it will fit most jeans, docker style pants). The wider belt helps to prevent the belt from twisting outward when carrying a concealed weapon. This keeps the weapon pulled in tight to the body and that conceals it better. I personally like Inside the Waist Band holsters, I have never been spotted when carrying with that style holster. I skive the tongue and buckle ends to minimize the bulk and make them easier to buckle up. They are very stiff when new and will loosen a little with use. John JOHN & WARREN, THOUGHT TO PONDER. this has happened to me before before you start cutting the belt strips, * measure the inside width of the buckle , to make sure that an 1-1/2" belt will fit. Quote Luke
