Members BlackDragon Posted April 29, 2023 Members Report Posted April 29, 2023 (edited) It's been 2 months and I finally brought home my Class 4 from Zack White's. I'm in the midst of setting it up but I noticed that the bottom pulley is at a slight angle. Is this normal or should I adjust the pulley height? Edited April 29, 2023 by BlackDragon Quote
DonInReno Posted April 29, 2023 Report Posted April 29, 2023 I do see how the reducer looks pulled to the side - is that what you were thinking? Belt tightness can vary quite a lot and be ok. I like them as loose as possible but tight enough to not squeak or slip. A belt loose enough to slip a bit if a needle or hook gets jammed up can prevent more serious damage. Eventually you’ll develop a feel for the situations more likely to break needles and go slowly over these areas and quickly let off the gas if things do lock up, but some of that experience involves breaking a few needles. Quote
Moderator Wizcrafts Posted April 29, 2023 Moderator Report Posted April 29, 2023 The pulleys should be directly inline. Any angle may cause premature wear on the belt. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members BlackDragon Posted April 30, 2023 Author Members Report Posted April 30, 2023 Thanks! I appreciate the help. I'll get everything aligned tomorrow and give it a go. Quote
Members BlackDragon Posted April 30, 2023 Author Members Report Posted April 30, 2023 Ok the issue wasnt the bottom pulley after all. When I was putting the machine together the youtube video I was watching had the pulley backwards like in the top picture. Watching the video that came with the machine (which I've seen on youtube before) had the pulley flipped around. I put the bottom pulley back where the manufacturer set it. Now everything looks like it's running as it should. Quote
DonInReno Posted May 2, 2023 Report Posted May 2, 2023 That’s funny - I totally missed the handwheel was backwards. Quote
