On 5/11/2023 at 9:27 AM, AlZilla said:
I don't have a design for you but I do have a caution. I've been working to reduce a 111w153 by putting a bigger hand wheel on it.
One thing I've learned is that hardware store pulleys aren't really very well balanced.
I'm probably just going to end up with a servo. I could probably balance those pulleys well enough by using the same process we used decades ago to "balance" motorcycle tires.  But it's reached the point of more work than I care to put into it.
I know exactly what you mean and that was my first concern with putting a bigger hand wheel on my leather sewing machine, believe it or not I had luck with taking a pulley off of a gas-powered air compressor. It's a little over 10 in in diameter and also balanced and it's nice and heavy duty cast iron, just look around for the old compressor pumps with the good size flywheel on them and they are most likely balanced.
  • Replies 40
  • Created
  • Last Reply
Top Posters In This Topic
