kgg Posted May 25, 2023 Report Posted May 25, 2023 4 hours ago, Wizcrafts said: I wonder if it is a special model double needle machine? I'm at a loss I guess it is possible. Maybe one of the dealers could answer. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members nylonRigging Posted May 25, 2023 Members Report Posted May 25, 2023 (edited) 1 hour ago, kgg said: I'm at a loss I guess it is possible. Maybe one of the dealers could answer. kgg All I know, is that having that particular tension plate assembly ( double knob ) is great because when swapping off from t-70 to #138 . All I have to do is just run thread routing off to the 2nd tension knob for that is already pre set . change needle, and I am sewing. I am betting that any recent production 1541s cast head with the single-knob . Can be easy swapped off to the other double knob assembly plate . If you look at the OP's pic. of his machine . You can even see the recessed indent in the casting above the assembly plate, for the small 'manual tension release lever' to fit into . . Edited May 25, 2023 by nylonRigging Quote
