I'm jsut wondering what some of you veteran braiders use to cut, split and bevel your strings. I do primarily rawhide work. I've been using a jerry stripper, and a hand plane to cut and split my strings. They work okay, but I've nothing to bevel them with and I want something that is a designed to do what i want.
Thanks!
I wouldn't say I'm a veteran braider but I have a knock off of the Hansen string cutter that the Hutterites traded for a bottle of vodka
"If you see your stirrups slap together above the saddle horn, you're probably bucked off"
Dave Stamey, The Bronc Ballet
I use a Hansen.
Vaya Con Dios, Alan Bell
If you know your history, then you would know where I'm coming from!
Bob Marley - Buffalo Soldier
My brother braids lots of rawhide, and he says, "I have a Hansen that works pretty well, but I don't care for the way it bevels. My all time favorite string cutter is the Bryan Neubert Rawhide String Cutter. Bryan is an excellent rawhider, and has spent lots of time perfecting this design. His website www.bryanneubert.com and it has his phone number. He is on the road right now, but should be back in a little over a week. For skiving, I use the one from Weaver. I like the Neubert cutter better than the Hansen because you can see the top of your strings when you bevel them, so you can see how much you are taking off. It is also easier to make super fine adjustments, and is more compact."
Good Luck, Spencer and David
"We are all worms, but I intend to be a glow worm." Winston Churchill
  • 2 weeks later...
This is the string cutter I use Wayne Jueschke out of elko made it, but I dont think he makes it any more
  • 2 years later...
You can check out mine I made I posted a video of it on youtube.
I need to weld some feet so I can attach it to my bench. Now i just hold it in a vice.
www.neveshorses.com
This one is mine that I use.
A demonstration video of the beveling part of it. Raw hide is a bit different with this type of tool though. From what I have found in my use with my tool is that it is better to just cut a wider 90 and then moisten your strings and then cut the 45 or 30 degree. But I don't use raw hide strings that much.
Best Regards,
Brian Kidd
Wow that's awesome. It's so space age looking. Is it made out of HDPE? Are you selling these?
www.neveshorses.com
Hi.
It's made of Delrin. Hard as steel and don't rust like steel. My friend PJ is selling them. Here's his page address if you're interested in one, PJ's Marlin Spike Shop... His email is at the bottom of the page.
Best regards,
Brian...
Best Regards,
Brian Kidd
My operation is probably the cheapest of the lot.
Cutting lace = Lace master tandy style but not tandy prices
Splitting lace = Hand made system with full adjustability upto an inch wide laces
Beveler = None, but seriously thinking about making something from what ever I find in the next skip...
Heres a quick video of the system.
http://www.youtube.com/watch?v=NADdAuqiUkc
Doing the right thing is bleeding for the cause.
Website
Facebook
Gday Brian
after watching your vid i am still not sure if the lace goes under the fence or does it just rub up against it , "the part that was meant to keep your finger from being cut "
