CFM Frodo Posted August 18, 2023 CFM Report Posted August 18, 2023 Like the title says, looking for suggestions I like stamping, And I like this pattern But, I am looking for a stamp to add to the vine Not this silly arse thing any suggestions? Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles
Members Gezzer Posted August 18, 2023 Members Report Posted August 18, 2023 This probably won't help since you already have leaves but I use long pear shader tilted quite a lot on just a swivel cut to make my vines . Like I said probably not much help . Quote
CFM Frodo Posted August 19, 2023 Author CFM Report Posted August 19, 2023 9 hours ago, Gezzer said: This probably won't help since you already have leaves but I use long pear shader tilted quite a lot on just a swivel cut to make my vines . Like I said probably not much help . Hey. l Iike that !!! cool stuff Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles
Contributing Member fredk Posted August 19, 2023 Contributing Member Report Posted August 19, 2023 (edited) Gezzer's is good Those are rose leaf stamps on the one you like At Le Prevo. Look under L, last two on top row - with rough edges are L948 & 949, and first two on bottom row, with smooth edges L953 & 954 http://www.leprevo.co.uk/stamps.htm#rx Tandy used to do the same ones You might have to search out your local Tandy stores or other places to find if they have them ~~ I just spotted that on the one you like the vine stalk is made using a rope border stamp Edited August 19, 2023 by fredk Quote Al speling misteaks aer all mi own werk..
CFM Frodo Posted August 19, 2023 Author CFM Report Posted August 19, 2023 Thanks Geezer, Here is my first attempt i will need to wrap the tool, it tends to twist in my hand and work on the angle a bit, but YES, this is the type of input I am looking for fredk. I am currently using the old Tandy 949 /948. They need to be updated the detail is no longer crisp the 953/954 look interesting I might give them a go yep, it is a rope stamp, you caught me. Lol i like the shape k Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles
Contributing Member fredk Posted August 19, 2023 Contributing Member Report Posted August 19, 2023 I wonder if a 'feather' stamp, like F120, used inside the pear shader would give some leafy look? Quote Al speling misteaks aer all mi own werk..
CFM Frodo Posted August 19, 2023 Author CFM Report Posted August 19, 2023 I am using the wrong pear Shader it looks like he is using the 209 and I am using the 206. Which is not as long take a look at f119 Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles
Members Gezzer Posted August 19, 2023 Members Report Posted August 19, 2023 Looking good Frodo . I am using a Craftjapan # P367 which some call a thumbprint and put my pinkie finger on the tip to keep from rolling . Quote
