Members MarlinDave Posted October 23, 2023 Members Report Posted October 23, 2023 Anybody spray Neatsfoot oil? I have some projects where I need to oil both sides of a dyed product. The rough side is wetformed convex and applying NFO with a rag takes a lot of the dye off. I have tried the water/starch type spray bottles and the NFO (and dye) lock up the little pump in the spray bottle. I hate to pull out the airbrush/mini paint gun for such a little amount of product applied. Anybody got a spray bottle that works? Thanks. Quote
Contributing Member fredk Posted October 23, 2023 Contributing Member Report Posted October 23, 2023 (edited) My NFO is quite thick, until its warmed up considerably. You'd need to thin the NFO quite a a bit, especially for the finer airbrush But there is car equipment for spraying heavier oils. There is a car under body protective called Waxoyl. Its very thick and you can get spraying equipment for spraying it on to the underneath of cars. Your compressor needs to be powerful though eg. Edited October 23, 2023 by fredk Quote Al speling misteaks aer all mi own werk..
Members dikman Posted October 23, 2023 Members Report Posted October 23, 2023 I doubt if any airbrush would be able to spray NFO, as Fred said it would need to be thinned a lot! Which then raises the question of which solvent to use? This would apply to spray bottles as well. It's not something I would even consider doing. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members MarlinDave Posted October 23, 2023 Author Members Report Posted October 23, 2023 I have seen people use a pump up sprayer similar to the one Fred pictured to apply mineral oil to hogs backs in the showring. I would guess mineral oil is a little lighter oil than NFO. Quote
