I have an early Singer 51w post bed machine (based on a W&W) and the upper section is pretty much the same just a bit shorter.
https://leatherworker.net/forum/topic/86292-singer-51w-sv-2-post-bed-machine-restoration/
I have a manual for the 51w and it will work for your machine too. The hook seems to be the same as well so the manual should cover everything.
Give me some time and I´ll upload it if the file is not too big...
EDIT:
well, this one should be even closer ;)
21_w_180.pdf
Edited by Constabulary
Yes, it is. Probably next to identical.
Thank you!
- Voltaire
- Aristotle
