JourneymanHandcraft Report post Posted November 30, 2023 Hi folks, I'm hoping you can help me, last year I bought a second hand 20T clicker press, worked fine initially then it started periodically not clicking. So it would turn on and run fine but when I press both buttons I can hear the switches engaging but no movement. Then it just started working consistently no problem for like 6 months so I forgot about it, however as it's getting cold in the workshop now it's stopped working again. -So now I'm thinking is this due to temperature? I've left it on for 30 mins and it hasn't warmed up and started working. -I'm not sure when it last had a oil change or even how much oil it has in it, I'm thinking this is the best place to start? If it doesn't have much oil in it would this be effected now it's colder as during the summer it was working fine. Any advice is very much appreciated, thank you Brian. Quote Share this post Link to post Share on other sites
DieselTech Report post Posted November 30, 2023 (edited) I would start by checking the hydrualic oil, & yes colder weather could affect it because the oil gets thicker as it gets colder. The other thing I would check is if your machine has a hydrualic drive motor to hydrualic pump coupler. Idk have a clicker press, but a think them would be best the best places to start. Edited November 30, 2023 by DieselTech Quote Share this post Link to post Share on other sites
maggielj Report post Posted February 6, 2024 I would for sure check oil level, possibly change it and any filters on the machine if its in the budget. Quote Share this post Link to post Share on other sites
