Members Wepster Posted May 1, 2024 Members Report Posted May 1, 2024 Does anyone other than me wonder if this post is a legit inquiry? Quote
Members Wyowally Posted May 1, 2024 Members Report Posted May 1, 2024 Oh, I think it is legit. As a very successful owner of one of these things, I've spent a lot of time getting mine right and trying to help others. There are many people with limited leather and sewing experience who buy them hoping they are a shortcut to getting away from hand sewing, or will help them get started on the cheap. There is a lot of frustration and disgust expressed by those hoping for plug and play. I believe our poster is legit and sincere, and just trying to tap whatever resources can be found to get it going. Success depends on the person and attitude, willingness to learn and listen and spend the time it takes. Many machines have been dumped or trashed. Others have been turned into smooth working motorized acceptable units by those with a lot of patience, money, and ambition. I haven't gone that route - mine does the limited non-production work I want without trying to make it something it is not. I try to follow advice from a friend - "just stay in your lane". ! Quote
CFM chuck123wapati Posted May 1, 2024 CFM Report Posted May 1, 2024 7 hours ago, Annikita said: That would actually be helpful - I realize the bearings are supposed to fit into the slots at the back of the wheel, but the inner bearing appears to be too far away from where the wheel is attached.... here ya go i can pull the thing apart if you need but you can just see the lower bearing in the first pic it rides about halfway out of the groove. The lower bearing runs the bobbin back and forth so it should slide easily back and forth while the bearing arm runs the needle arm up and down. You should be able to slide the bobbin shaft and bearing back or forward to get the bearing into the inner smaller raceway. If it wont move something is wrong. As Wyowally said these things need to be tinkered with a bit before they run smoothly and there are tons of youtubes on that subject. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
CFM chuck123wapati Posted May 1, 2024 CFM Report Posted May 1, 2024 once you get it figured out how to put it together then you will need to take it apart and polish the arms where they make contact as well as the cams and bobbin shaft. The hole in the arm where the thread goes through should be polished. The foot needs work as well they usually are so roughly made they tear up the leather. There are several ways that people have fixed the feet but what i did was to clean up the teeth with a jewelers file so they didn't have the ragged edges now they grab fine and move the leather but don't scratch or rip it up. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members Annikita Posted May 3, 2024 Author Members Report Posted May 3, 2024 On 5/1/2024 at 10:27 AM, Wyowally said: Oh, I think it is legit. As a very successful owner of one of these things, I've spent a lot of time getting mine right and trying to help others. There are many people with limited leather and sewing experience who buy them hoping they are a shortcut to getting away from hand sewing, or will help them get started on the cheap. There is a lot of frustration and disgust expressed by those hoping for plug and play. I believe our poster is legit and sincere, and just trying to tap whatever resources can be found to get it going. Success depends on the person and attitude, willingness to learn and listen and spend the time it takes. Many machines have been dumped or trashed. Others have been turned into smooth working motorized acceptable units by those with a lot of patience, money, and ambition. I haven't gone that route - mine does the limited non-production work I want without trying to make it something it is not. I try to follow advice from a friend - "just stay in your lane". ! Thank you for having faith in me... Quote
Members Annikita Posted May 3, 2024 Author Members Report Posted May 3, 2024 On 5/1/2024 at 10:53 AM, chuck123wapati said: here ya go i can pull the thing apart if you need but you can just see the lower bearing in the first pic it rides about halfway out of the groove. The lower bearing runs the bobbin back and forth so it should slide easily back and forth while the bearing arm runs the needle arm up and down. You should be able to slide the bobbin shaft and bearing back or forward to get the bearing into the inner smaller raceway. If it wont move something is wrong. As Wyowally said these things need to be tinkered with a bit before they run smoothly and there are tons of youtubes on that subject. OK, so I took some pics that I think demonstrate the dilemma I'm having. See where the bearing is located in relation to the inner circle? It can't possibly fit there because of the distance between the wheel mounting point and the bearing. I was able to get the wheel on (with the notch in the right place) and both bearings fit into the OUTSIDE ring, but once I secure it the wheel no longer moves....I have yet to determine if that's because of the bearings or some other issue, but I feel like the bearings are bound to be a problem. Quote
Members Annikita Posted May 3, 2024 Author Members Report Posted May 3, 2024 On 4/30/2024 at 6:15 AM, Mulesaw said: @Annikita I think that the two bolts/nuts on the left of the sliding bar are for adjusting the timing of the shuttle. So I wouldn't start moving those around yet. My guess is that the machine is set at some coarse adjustment so that it should be possible to sew with it. But you could make small adjustments with the timing later. To me it seems as the inner bearing is in the correct place. It is supporting the shaft and it is held in the main casting, so that looks good. as @Wepster says, the two smaller bearings should most likely go into a groove on the backside of the wheel. Did the machine come with an installation manual or some sort of assembly instructions? Brgds Jonas So, here's the issue I'm talking about. I should have posted this first. The bearing that is typically supposed to fit the inner groove (according to the manuals/videos I've seen) can't possibly align with the groove properly. It fits the outer groove when I try to put everything together, but I think it may be inhibiting the wheel from moving properly? Quote
Members Annikita Posted May 3, 2024 Author Members Report Posted May 3, 2024 On 5/1/2024 at 4:58 AM, Wepster said: The bearing on the shaft looks fine it the pic. just behind the the little protruding screw that the notch in wheel fits over. Did you fit the wheel notch over that? So here's the issue with that - my understanding is that the inner groove is supposed to fit over the bearing to the left. Well, as you can see in the pic below - that isn't possible. It does fit into the outer groove, but then once I put everything else into place, the wheel doesn't move.... Quote
CFM chuck123wapati Posted May 3, 2024 CFM Report Posted May 3, 2024 14 minutes ago, Annikita said: So here's the issue with that - my understanding is that the inner groove is supposed to fit over the bearing to the left. Well, as you can see in the pic below - that isn't possible. It does fit into the outer groove, but then once I put everything else into place, the wheel doesn't move.... if the wheel wont move then the bobbin shaft or something inside the arm is jammed up. ok if the bearing and shaft its connected to wont move freely back and forth then you have a problem inside the arm. the bearing isn't the problem you should be able to easily move it back and forth. you are going to have to take it apart to figure out what is jammed up. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members GerryR Posted May 3, 2024 Members Report Posted May 3, 2024 You need to slide the shaft out manually so it does fit in the inner groove. Once you have both bearings in their proper grooves, the handwheel should be in alligmment with the pin on the shaft. Quote
