Members sturner767 Posted June 17, 2024 Members Report Posted June 17, 2024 I have recently purchased a 29k58. Upon trying to sew with it I found that no matter where I adjust the stitch length bar it doesn't change and is very tight stitching when you operate it the way it's supposed to by turning the wheel to you. However if you turn the wheel clockwise, ( I know your not supposed to) it will make a perfect stitch and you can adjust the length by the adjustment mechanism, however the material is going backwards. Any ideas? Quote
Uwe Posted June 17, 2024 Report Posted June 17, 2024 If your hand-wheel is attached to the front of the machine, then the correct way to operate machine manually is indeed to turn the hand wheel clock-wise. Quote Uwe (pronounced "OOH-vuh" ) Links: Videos
Members sturner767 Posted June 17, 2024 Author Members Report Posted June 17, 2024 It is on the end. Not the front. Quote
Members shoepatcher Posted June 17, 2024 Members Report Posted June 17, 2024 The cam at the end which is has the race on one side and the pulley slot on the top of the wheel is out 180 degrees. Need to be depinned and moved 180 degrees. glenn Quote
Members sturner767 Posted June 17, 2024 Author Members Report Posted June 17, 2024 Glen, would you have a picture of what your talking about? Quote
Moderator Wizcrafts Posted June 18, 2024 Moderator Report Posted June 18, 2024 8 hours ago, sturner767 said: Glen, would you have a picture of what your talking about? Glenn was letting you know that the cam on the back is fitted onto the top shaft with a solid tapered pin. You'll need to rotate the hand wheel to bring that pin to the top, then pound it out with a drift punch. Note, the pin is tapered and only comes out in one direction, which I don't know about. After loosening the cam, hold the wheel and rotate the cam until the hole on the other side is facing up. Then pound in the tapered pin and test the machine. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
