for what its worth.
Some thoughts....
how about the frame? you will need to come up with a motor mount too.
if you are changing the height, i would make sure that you can do that 1st and if possible sometype of mechanical/pneumatic or? to do it easier.
that also goes for the controls too.
a thought.  I dont know how much room you have to work in/around.  But if you build your new table top to cantilever the right side of the HD bench and position the base of the machine over the legs, that could be enough support so all you need is some thicker/rigid table top.  It would also give you more table top work/sewing space.
good luck
Riding is a partnership. The horse lends you his strength, speed and grace, which are greater then yours. For your part you give him your guidance, intelligence and understanding, which are greater then his. Togeather you can achieve a richness that alone neither can.
- Lucy Rees, The Horse's Mind
