Members JWfur Posted August 9, 2024 Members Report Posted August 9, 2024 I'm new here, thanks for letting me in. I clicked the techsew add up top. What's your opinion on the 5100? It says it will sew wallets to thick leather Quote
kgg Posted August 9, 2024 Report Posted August 9, 2024 9 hours ago, JWfur said: What's your opinion on the 5100? It says it will sew wallets to thick leather This is a class 441 clone machine of the Juki TSC-441 and is similar to the Cowboy 4500, the Cobra Class 4 along with other machines in this class. These days they all seem to be pretty dependable. The main question that should first be answered is this class of machine the right one for what you want or need to sew. This article will help you determine what machine or machines will best suit your needs. What are you planning on sewing and with what size of thread???? kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members JWfur Posted August 9, 2024 Author Members Report Posted August 9, 2024 I have read that, it was very good. In fact I took notes. I've been lurking around here for a while now. If the 5100 I mentioned will sew everything from wallets to tack, it's the one for me. I want to be as versatile as possible. This is an example of some of the stuff we do right now. Lots of work with fur, some leather work. I want to do more leather work and I'm buying a machine for the future. ( if that makes sense) I will be doing knife sheaths for one customer, bags for another and maybe even fixing horse tack. I need to be versatile and open to anything. At least I need to have the equipment to be able to. Quote
Moderator Wizcrafts Posted August 9, 2024 Moderator Report Posted August 9, 2024 The 5100 can sew fur items if you install the blanket foot set made for it. This set has teeth on the feet and feed dog that help grab slippery material. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members JWfur Posted August 9, 2024 Author Members Report Posted August 9, 2024 Wizcrafts, I have fur sewing machines. I don't want it to sew fur. I'm just curious as to the variety of leather it can handle. I would like a cylinder machine with a flat bed option, that will handle the widest variety. Quote
AlZilla Posted August 9, 2024 Report Posted August 9, 2024 (edited) 1 hour ago, JWfur said: Wizcrafts, I have fur sewing machines. I don't want it to sew fur. I'm just curious as to the variety of leather it can handle. I would like a cylinder machine with a flat bed option, that will handle the widest variety. It's all really going to depend on how thin you want to go and how small the thread/needle size you'll want to use. For me, a 111W with 138 complementing a 441 class kept setup with 277 fits the bill. The following article talks about how to "dumb down" a 441 class machine for lighter work. It should help you decide if the 441 is the right fit. There's a video somewhere online of a machine similar to these sewing through plywood, so upsize is definitely not the issue. You mentioned wallets, which the article specifically mentions as a case for "dumbing down" the 441. Edited August 10, 2024 by AlZilla Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Members JWfur Posted August 10, 2024 Author Members Report Posted August 10, 2024 Excellent reading, thank you. Quote
Moderator Wizcrafts Posted August 10, 2024 Moderator Report Posted August 10, 2024 @JWfur If you intend to use a 441 clone to sew thin or soft materials using thin needles and thread, you'll probably need to upgrade the stock feed dog and throat plate to a narrower set that resists the tendency of some materials to get shoved down into the cutout in the throat plate and the oval hole in the feed dog. These aftermarket feet and throat plates are made by one of our members. His website is here. I use some of his items. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
kgg Posted August 10, 2024 Report Posted August 10, 2024 15 hours ago, JWfur said: I want to do more leather work and I'm buying a machine for the future. ( if that makes sense) I will be doing knife sheaths for one customer, bags for another and maybe even fixing horse tack. 13 hours ago, JWfur said: I would like a cylinder machine with a flat bed option, that will handle the widest variety. Keep in mind no one machine will do everything well and most of industrial sewing machine do not like using V69 thread preferring V92 and larger. That is why a lot of us have more then one class (Upholstery Class 563/1541, Class 341/1341, Class 441) or style machine (Flatbed, Patcher, Cylinder Arm). I think as an all rounder with a flatbed attachment that are rated to sew about 7/16" thick leather you may want to consider the Class 341/1341 machines similar to the Cowboy 341, Cobra Class 26 and the Techsew 2750 to name a few. They use the 135X16 needle system for leather and 135x17 needle system for fabric. The Class 441 machines can do thin stuff if properly dumbed down and with the right feet dogs/presser feet/needle plate but really shine at the doing the really thick items. Keep in mind that they take a large diameter needle the 7x3 or 794 needles and may not give you a nice looking finished item with small sized thread. As a visual comparison think of a 3" finishing nail punching a hole vs a 1" finishing nail. I guess it really comes down to which machine that will do most of your items most efficiently. You may find it better to get a Class 341 / 1341 cylinder arm now and if the need arises then invest in a Class 441. As this is going to be an expensive investment I would suggest making a road trip to a dealer (or sending a sample of your items to a dealer) and test driving a couple different classes and styles of machines using the thread size you want to use. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members JWfur Posted August 10, 2024 Author Members Report Posted August 10, 2024 @AlZilla @Wizcrafts @kgg Thank you guys for your help. I appreciate it. I tried to quote and add a pic but that reply went bad. I don't know what I did wrong, I apologize for whatever happened. Anyway, after thinking more about it, I'm wondering if the 4800 might be the answer? I'm not stuck on a particular brand, but I've heard good things about techsew customer service/warranty. The 4800 if I'm reading the descriptions right, should sew 3-5 oz leather as well as the occasional heavy tack repair? Is there an advantage to one brand over the other? The cowboy brand I think I could find close enough to drive to. The others don't seem to be the case. What would the 4800 be in the other brands? As I said before, without the experience all I can go by is the written description. Which isn't always completely accurate I guess. h Quote
