ZARDOZ the GREAT Report post Posted August 14, 2024 Hello! I have a question about cartridge belts for Victorian era/old West styles. I've heard some people say that the belts fit a lot better if they are pre-curved. Some people say it doesn't matter. I've done the pre-curve by making a sort of wooden template, wetting a straight cut blank, and letting it dry in the template… and it took the curve and it works fine. However, my concern is cutting the cartridge loops on a curved belt. I have a straight cartridge loophole template, and it seems overly complicated trying to get those loops cut on a curve. I figure another option could be making the belt straight and then doing the curve by wetting it after the loops are on there and leaving the cartridges in the loops to prevent any warping. However, this seems like it would create its own set of complications with the lining, etc. Has anybody done this? I also would like to make some money-belts or better said money cartridge belts, and I'm wondering if it's the same deal with that. I tend to think that making all of them straight is fine and then, maybe, wetting them and adding a curve after it's all done will work fine also, but I've never done that before and don't want to reinvent the wheel. Looking forward to your input. Thanks. Quote Share this post Link to post Share on other sites
Cattleman Report post Posted August 15, 2024 (edited) First off... Pre-stretch the straps used to create the cartridge loops, BEFORE building the belt. Then once you have finished the construction of the belt, but before oiling and finishing, buckle it tightly around a 5 gallon bucket or a 30 gallon drum (with a cartridge in each loop) while its slightly moist. Allow it completely dry, then remove to apply oil and finish products. Edited August 15, 2024 by Cattleman Typo Quote Share this post Link to post Share on other sites
ZARDOZ the GREAT Report post Posted August 15, 2024 36 minutes ago, Cattleman said: First off... Pre-stretch the straps used to create the cartridge loops, BEFORE building the belt. Then once you have finished the construction of the belt, but before oiling and finishing, buckle it tightly around a 5 gallon bucket or a 30 gallon drum (with a cartridge in each loop) while its slightly moist. Allow it completely dry, then remove to apply oil and finish products. That seems like a helpful technique, but what about the curve? Seems this technique would be detrimental to a pre-added curve, and visa versa. A moneybelt wouldn't have a curve, so this seems to make a case against it. Any input on whether the curved belt really makes a difference? Also, adding the stain etc. at the end will affect the stitching color. Quote Share this post Link to post Share on other sites
Cattleman Report post Posted August 15, 2024 I usually stitch those type of items black... So I dont have to worry about staining the stitching. As to whether the curve makes a difference... I think that really varies client to client. Quote Share this post Link to post Share on other sites
ZARDOZ the GREAT Report post Posted August 15, 2024 4 minutes ago, Cattleman said: I usually stitch those type of items black... So I dont have to worry about staining the stitching. As to whether the curve makes a difference... I think that really varies client to client. That would work. I do like the lighter stitching though. Seems like the pre-curve would be more for thick, stiff belts. Quote Share this post Link to post Share on other sites
Mablung Report post Posted August 15, 2024 The pre-curve bit is a lot more about creating a shortcut around the break-in process for a standard gun belt going through one’s belt loops. I doubt strongly that it makes a considerable difference for a separate cartridge gun belt, though I could be wrong. I’d not worry about it, personally. Now to fit the loops along the belt, if you go ahead and pre-curve it, I’d be more inclined to simply leave off the loops along the middle couple inches of the belt. That’s where the curve will be, so just leave those out, unless it’s critical that the loops cover the whole surface. Quote Share this post Link to post Share on other sites
Dwight Report post Posted August 15, 2024 John Bianchi has for me the last word in gun holster making . . . seeing as how he more or less invented the fast draw concept . . . In his video he shows to cut the blanks out of one piece of leather . . . with the curve cut in it. He also shows that on I believe it was about a 42 inch belt . . . that the curve was a bow about 6 inches deep at the center . . . with the two ends of the belt being the ends of the bow. Those who make straight belts don't take into consideration that men generally wear their britches belted at their lower waist . . . and the gun belt goes below that on their hips. Many guys don't like the idea that they have a curve in the profile of their butt . . . but they do. They are a lot bigger around 3 inches below the belt . . . than they are at the belt. Hence . . . thee curved belt which makes up for the butt curve. Wide belts cut straight will be tighter at the bottom than the top . . . and if not cinched up . . . one good sneeze and the gunbelt is on the ground. Cut em straight if you want to . . . I've followed John's directions for over 20 years . . . never had but one come back . . . he ordered a 53 inch . . . it took a couple months to get it in the system and out to him . . . by that time he needed a 56 inch. Thankfully I was able to just barely change the tongue and he was happy. Never had one problem with them falling down. Your attitude may vary. May God bless, Dwight Quote Share this post Link to post Share on other sites
ZARDOZ the GREAT Report post Posted August 15, 2024 The Bianchi method seems valid, though I have owned two Bianchi cartridge belts that had no curve. That being said... did Bianchi ever explain cutting the cartridge loops on a curved belt? Unless it' as simple as cutting and adding the loops and then giving the curve by wetting and forming the belt... Quote Share this post Link to post Share on other sites
Dwight Report post Posted August 16, 2024 This is how I do the loops on a curved belt. The little tool that looks like a T is simply two pieces of 1/4 " plywood glued together at 90 degrees. On it . . . there is an arrow you can see jut to the right of the up and down bar. The distance from the bar to the arrow is 5/8 of an inch . . . the proper spacing for 44 and 45 cartridges. On the up and down bar are two lines that come out to the edge . . . they indicate the length the hole needs to be. I take an ink pen and draw a line from one line down to the next . . . while my arrow is pointing to the line I drew last. When I get done marking the lines . . . I get my slotting tool . . . and go to work. The line is made just the length of the slotting tool . . . so I put the top of the slot at the top of the line . . . bring the bottom down so it is centered . . . and I hammer a hole in the leather. Repeat until the proper number of holes are done. For modern six shooters I usually do 24 . . . for the old fashioned ones without a transfer bar . . . I do 25. The punch is made from a piece of 1/2 inch EMT conduit . . . smashed in a vise . . . and a 1/8 inch piece of flat stock steel forced into the hole to make both sides parallel . . . took it to a belt sander and sharpened the outside . . . took a round file and took off the burrs on the inside . . . have no idea of the number of cartridge holes this rascal has punched. But anyway . . . that is how I do it . . . never any complaints so far. May God bless, Dwight Quote Share this post Link to post Share on other sites
CdK Report post Posted August 16, 2024 10 hours ago, Dwight said: This is how I do the loops on a curved belt. The little tool that looks like a T is simply two pieces of 1/4 " plywood glued together at 90 degrees. On it . . . there is an arrow you can see jut to the right of the up and down bar. The distance from the bar to the arrow is 5/8 of an inch . . . the proper spacing for 44 and 45 cartridges. On the up and down bar are two lines that come out to the edge . . . they indicate the length the hole needs to be. I take an ink pen and draw a line from one line down to the next . . . while my arrow is pointing to the line I drew last. When I get done marking the lines . . . I get my slotting tool . . . and go to work. The line is made just the length of the slotting tool . . . so I put the top of the slot at the top of the line . . . bring the bottom down so it is centered . . . and I hammer a hole in the leather. Repeat until the proper number of holes are done. For modern six shooters I usually do 24 . . . for the old fashioned ones without a transfer bar . . . I do 25. The punch is made from a piece of 1/2 inch EMT conduit . . . smashed in a vise . . . and a 1/8 inch piece of flat stock steel forced into the hole to make both sides parallel . . . took it to a belt sander and sharpened the outside . . . took a round file and took off the burrs on the inside . . . have no idea of the number of cartridge holes this rascal has punched. But anyway . . . that is how I do it . . . never any complaints so far. May God bless, Dwight Simple and elegant tool & method described here, I’ll lodge this in my mind if I venture into doing this kind of project. Quote Share this post Link to post Share on other sites
Littlef Report post Posted August 16, 2024 10 hours ago, Dwight said: This is how I do the loops on a curved belt. The little tool that looks like a T is simply two pieces of 1/4 " plywood glued together at 90 degrees. On it . . . there is an arrow you can see jut to the right of the up and down bar. The distance from the bar to the arrow is 5/8 of an inch . . . the proper spacing for 44 and 45 cartridges. On the up and down bar are two lines that come out to the edge . . . they indicate the length the hole needs to be. I take an ink pen and draw a line from one line down to the next . . . while my arrow is pointing to the line I drew last. When I get done marking the lines . . . I get my slotting tool . . . and go to work. The line is made just the length of the slotting tool . . . so I put the top of the slot at the top of the line . . . bring the bottom down so it is centered . . . and I hammer a hole in the leather. Repeat until the proper number of holes are done. For modern six shooters I usually do 24 . . . for the old fashioned ones without a transfer bar . . . I do 25. The punch is made from a piece of 1/2 inch EMT conduit . . . smashed in a vise . . . and a 1/8 inch piece of flat stock steel forced into the hole to make both sides parallel . . . took it to a belt sander and sharpened the outside . . . took a round file and took off the burrs on the inside . . . have no idea of the number of cartridge holes this rascal has punched. But anyway . . . that is how I do it . . . never any complaints so far. May God bless, Dwight wow, that's a slick simple solution to follow the curve. Thank you for showing this Dwight! Quote Share this post Link to post Share on other sites
Dwight Report post Posted August 16, 2024 Cdk . . . Littlef . . . now you got the crown secrets . . . use em wisely May God bless, Dwight Quote Share this post Link to post Share on other sites
dikman Report post Posted August 16, 2024 Personally, I reckon you're overthinking the whole thing. Any curve on the belt is unlikely to be great enough to be an issue for boolit loops. Quote Share this post Link to post Share on other sites
Littlef Report post Posted August 17, 2024 19 hours ago, Dwight said: Cdk . . . Littlef . . . now you got the crown secrets . . . use em wisely May God bless, Dwight lol, that you sir. With great knowledge comes great responsibility. Quote Share this post Link to post Share on other sites
