Members Agent319 Posted September 20, 2024 Members Report Posted September 20, 2024 I have a 211W155 and a 211G156 and I have the exploded parts view diagram of these machines. In the diagram the screw parts listed have either a -803, 804, 805, 806, 819, 830, 833, 850 or 819 after the part # and many of those -#'s are the same. Would anyone know what those dash #'s represent? Quote
Members Agent319 Posted September 26, 2024 Author Members Report Posted September 26, 2024 I came across this https://www.singersewinginfo.co.uk/screw_threads "Because Singer factories manufactured all of their own components it was not as important for them to ensure standardization of items from different suppliers. Although many older Singer threads matched those of the American and then Unified standards, they continued to use some sizes that were non-standard in order to maintain backward compatibility between parts that were common to different models." Those -#'s after a screw part # is Singer tap/die# used to cut the threads for a screw or a hole. Quote
Moderator Wizcrafts Posted September 26, 2024 Moderator Report Posted September 26, 2024 1 hour ago, Agent319 said: Those -#'s after a screw part # is Singer tap/die# used to cut the threads for a screw or a hole. That's good to know! @CowboyBob has sets of actual Singer taps and dies that he uses to repair old Singer sewing machines in his shop: Toledo Industrial Sewing Machines. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
CowboyBob Posted September 27, 2024 Report Posted September 27, 2024 (edited) 20 hours ago, Wizcrafts said: That's good to know! @CowboyBob has sets of actual Singer taps and dies that he uses to repair old Singer sewing machines in his shop: Toledo Industrial Sewing Machines. The problem with the 211 is it doesn't use many of the standard screws for previous models (look @ the tap chart I attached) AFAIK the tap kit is NLA either just like most of the screws & many parts for a 211. page0096.pdf Edited September 27, 2024 by CowboyBob Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
