dleger Report post Posted Tuesday at 03:12 PM (edited) Hello Everyone, I'm new here and new to my machine. I have a pfaff 335 machine I picked up. I bought it to do hockey glove palms and a few other things. It's a 335-H3-17/18 with an "L" below that. The machine works well, but the previous owner ground up the presser feet and throat plate. Which makes it a bit difficult to get the material to flow well. So I ordered some from aliexpress. The presser feet were a bit tall, but I found a video on here that I think will help me adjust the height of the presser foot shaft (It's German so I'm guessing). However, the feed dog and presser plate seem to be a bit off. I'd need to shift the needle to the right a smidge. so that it enters the hold properly. I also assume I would need to adjust the timing and rotary hook, but I know how to do that. My question is, can I move the shaft left to right? And if so, how do I do that? Edited Tuesday at 03:16 PM by dleger Quote Share this post Link to post Share on other sites
Northmount Report post Posted Tuesday at 03:27 PM 13 minutes ago, dleger said: I'm new here and new to my machine. I have a pfaff 335 machine I picked up. I bought it to do hockey glove palms and a few other things. It's a 335-H3-17/18 with an "L" below that. Moved your post to leather sewing machines. This is where the machine guys hang out and will get better responses. Quote Share this post Link to post Share on other sites
nejcek74 Report post Posted Tuesday at 04:22 PM here is link to adjustment manual https://www.pfaff-industrial.com/db-downloads/technicaldoc/justieranleitungen/300/ja_335_11-15_en.pdf/%40%40download/file/JA_335_11-15_EN.pdf&ved=2ahUKEwiw1s39yu2IAxXPhv0HHbtnFy4QFnoECAYQAQ&usg=AOvVaw2VOmT4xRzYBqKvIHAfTiF1 adjustment "Needle position to needle hole" is on page 8, and is one of the first when doing the timing adjustments. Everything else you need to know/follow is there too. Quote Share this post Link to post Share on other sites
shoepatcher Report post Posted Tuesday at 08:33 PM (edited) Pics of the head first please so I can see the feet and the cover pate set up. If it is 335-17, that is the binder machine. For repalming, you need it set up to sew on the edge of the of the fingers. A binder will do binding but will make sewing other parts very hard. send me a few pics please. I can help you set it corcrrectly. Bend doing to it a few years. You may need the plain sewing parts. I also repair shoepatchers. glenn miller Edited Tuesday at 08:38 PM by shoepatcher Quote Share this post Link to post Share on other sites
robinsone Report post Posted Tuesday at 11:06 PM I sent you a private message I can help, certified expert in all things 335 legacy or contemporary machines Quote Share this post Link to post Share on other sites
dleger00 Report post Posted Wednesday at 03:46 PM 19 hours ago, shoepatcher said: Pics of the head first please so I can see the feet and the cover pate set up. If it is 335-17, that is the binder machine. For repalming, you need it set up to sew on the edge of the of the fingers. A binder will do binding but will make sewing other parts very hard. send me a few pics please. I can help you set it corcrrectly. Bend doing to it a few years. You may need the plain sewing parts. I also repair shoepatchers. glenn miller Hi Glenn, Thank you. I feel like we'll get to know one another over time. I'm sure we'll come across each other time and time again over the next while. I also purchased a Landis SL-71 which works, but I will definitely want to refurbish a little, a singer 29K which needs to be repaired (though I haven't examined it yet) and an adler patcher (which I haven't really looked at either) which I'm told needs work also. But that's a project for another day. Is this the photo you need? I also purchased some other presser feet, which I think I now know how to setup properly. I have one that I think is originally for a zipper which I feel like it might work? The original that I got with the machine was removed, but I still have it. It was filed down to remove the right side of the foot. On 10/1/2024 at 11:27 AM, Northmount said: Moved your post to leather sewing machines. This is where the machine guys hang out and will get better responses. Thank you. I will keep that in mind for the next questions. Much appreciated. Quote Share this post Link to post Share on other sites
dleger00 Report post Posted Wednesday at 03:48 PM 23 hours ago, nejcek74 said: here is link to adjustment manual https://www.pfaff-industrial.com/db-downloads/technicaldoc/justieranleitungen/300/ja_335_11-15_en.pdf/%40%40download/file/JA_335_11-15_EN.pdf&ved=2ahUKEwiw1s39yu2IAxXPhv0HHbtnFy4QFnoECAYQAQ&usg=AOvVaw2VOmT4xRzYBqKvIHAfTiF1 adjustment "Needle position to needle hole" is on page 8, and is one of the first when doing the timing adjustments. Everything else you need to know/follow is there too. Thank you. My machine is quite a bit older, though my understanding is that they are fairly similar when it comes to this stuff. I will take a look and see if I can follow these instructions. Quote Share this post Link to post Share on other sites
dleger00 Report post Posted Wednesday at 05:37 PM 18 hours ago, robinsone said: I sent you a private message I can help, certified expert in all things 335 legacy or contemporary machines Thanks. I didn't get any PM's. So just know I'm not ignoring you. Quote Share this post Link to post Share on other sites
shoepatcher Report post Posted Wednesday at 05:59 PM Yes as to the photo. You can adjust the feed dog left to right to center the needle in the middle of the hole in the feed dog. Move the cover plate and that gets you access to the feed dog screws. Pics of the head on your machine please. The SL-71 was one Landis had built. It is a clone of a 29K71. Parts should be interchangeable. glenn Quote Share this post Link to post Share on other sites
