Hi, I need some infos, I have a cylinder arm (GC2603 Typical), I got it used and it was installed on a regular table, no belly cut. While it works for most my sewing I recently started to use metal frames in my bag. The problem is I can not turn the bag around the free arm as it is about 6 inches over the surface of the table. I either want to cut a 14 x 14 belly on my table or cut it completely so my arm is really free. Then I will need to cut my k legs support bars to fit the new width, re-install the leg, move the knee lift and probably other things... So do you know a place I could get either a pedestal or a half size table already mounted on stable legs. Any other ideas are welcome, by the way, I am in Canada.
Edited by Northmount
Changed Title from Username
  • 1 month later...
Hi. Look for a company that sells CowBoy sewing  machines, They can furnish a pedestal stand
"The gun fight at the O.K. corral was actually started by two saddlemakers sitting around a bottle of whiskey talking about saddle fitting"...
I think both Cowboy & Cobra both sell a pedestal stand. But they are pricey, around $650 I believe.
I recently priced all the correct steel to fabricate a pedestal stand like Cobra or Cowboy sales. I had $200 just in steel.
