The limiting pin on my Tandy pro press recently broke. Do any of you know what size pin is needed to replace it? Thanks in advance for your help!
I have a Tandy Pro-Press and it doesn't have any such 'limiting pin'
Are you referring to the limiting pin that mounts in the handle? Referred to as the "stop pin" in the instruction manual?
https://cdn.shopify.com/s/files/1/0063/5997/3970/files/PKG-21-003_TandyPro_Hand_Press_-_Instructions_NO_CROPS.pdf?v=1631115666
Edited by Arturomex
Mea culpa
Caveat; my press is an earlier version in grey
The pin is shanked on both sides. It is approx 5.8 mm (15/64 inch ?) on the outside (both sides) and is straight cut narrowed from approx 6.5 mm (1/4 inch ?) which goes thru the handle. It is approx 30.85 mm  (1 7/32 inches ?)  long, but has room to be a slightly longer
