Members AndreaIbis Posted November 27, 2024 Members Report Posted November 27, 2024 I recently bought a Bernina 217 6 mm zig zag. I saw a 6mm to 12mm zigzag conversion kit on a Bernina 217 sparenparts. Other people managed to convert. I open this post to share the experience and have suggestions if someone has already done it. Quote
Members Constabulary Posted November 27, 2024 Members Report Posted November 27, 2024 Very interesting! I´m wondering if this kit is still available and how many hundred € it will cost. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members AndreaIbis Posted November 27, 2024 Author Members Report Posted November 27, 2024 24 minutes ago, Constabulary said: Very interesting! I´m wondering if this kit is still available and how many hundred € it will cost. I'm also studying, I'm looking for someone who has already made this change Quote
Members AndreaIbis Posted November 29, 2024 Author Members Report Posted November 29, 2024 I found the kit available at Global, in practice they produce a car equal to the Bernina the Global zz217. I would like to understand if anyone has tried to make this modification to bring the machine to 12 mm I already have the offer and it is not so high but when I ask if the kit is compatible with the Bernina, they don't answer me. Quote
Members AndreaIbis Posted December 4, 2024 Author Members Report Posted December 4, 2024 I ordered the Bernina 217 conversion kit from 6mm to 12mm, from Global Parts in Holland. Ich habe den Umbausatz Bernina 217 von 6mm auf 12mm bei Global Parts in den Niederlanden bestellt. Quote
Members Michiel Posted December 5, 2024 Members Report Posted December 5, 2024 Very interesting what did the set cost? en can you post a picture of your bernina? kind regards , michiel Quote
Members AndreaIbis Posted December 7, 2024 Author Members Report Posted December 7, 2024 On 12/5/2024 at 10:13 PM, Michiel said: Molto interessante quanto è costato il set? en puoi postare una foto della tua bernina? Cordiali saluti, michiel Mine is a normal Bernina here I have no photo the seven you have to make the request and they make you an offer with the transport Quote
Members AndreaIbis Posted December 9, 2024 Author Members Report Posted December 9, 2024 Stücke angekommen Quote
Members AndreaIbis Posted November 1 Author Members Report Posted November 1 (edited) Nach fast einem Jahr habe ich es endlich geschafft, alles zusammenzubauen und die ersten Tests durchzuführen. Es war gar nicht so einfach, ich bin schließlich kein Nähmaschinenmechaniker, aber sie funktioniert. Nur die maximale Zickzackstichlänge von 9–10 mm ist nicht wie erwartet (statt 12 mm). Vielleicht muss man da etwas einstellen, aber ich komme im Moment nicht drauf. Es gab ein kleines Kompatibilitätsproblem mit den Zahnrädern und den Schrägverzahnungen, da sie nicht richtig in das vorhandene Zahnrad passten. Mit etwas Schmirgelpaste habe ich die Maschine ein bisschen gedreht, und dann hat es geklappt. Edited to post Google Translation: After almost a year, I finally managed to assemble everything and do the first tests. It wasn't easy at all; after all, I'm no sewing machine mechanic, but it works. Only the maximum zigzag stitch length of 9–10 mm isn't as expected (instead of 12 mm). Perhaps something needs adjusting, but I can't figure it out at the moment. There was a minor compatibility issue with the gears and the helical gears, as they didn't fit properly into the existing gear. I used some emery paste to rotate the machine a little, and then it worked. Edited November 1 by Northmount Added English Translation Quote
Members AndreaIbis Posted November 1 Author Members Report Posted November 1 (edited) Ich habe auch noch dieses rot eingekreiste Teil übrig, von dem ich nicht weiß, wofür es ist und wo ich es hinstellen soll. Edited to add English Translation I also have this part circled in red left over, which I don't know what it's for or where to put. Edited November 1 by Northmount Added Eglish Translation Quote
