Moderator bruce johnson Posted December 16, 2007 Moderator Report Posted December 16, 2007 I have had a running email deal with a guy today who is relining some skirts. Fairly common repair, and it started out to be a "Barge vs. rubber cement discussion". He was not relishing the 1-2 hours of picking stitches, and wanted to use the old stitch line. It is an older family handed down saddle, and sentimental as well as moderate collectible value. If you use a seam ripper, flat knife, or anything else between the sheepskin and the leather, it cuts the stitches, and never fails, the lock is buried in the skirt. You have to take each stitch out one at a time. They are old, they are hard, they don't want to come out. You cheer when you can pull a tag and get 3-4 stitches at once. . About 10 years ago, an older maker took pity on a younger guy and shared this tip. Since my pal who has done this sort of work for longer than me hadn't heard it, he shamed me into passing it along. Before you do anything on the wool side, take a stitch groover on the top side and run it over the stitches. One with the loop blade like Osborne's compass style groover works best. Running it over the stitches cuts and removes the top stitch, or severely weakens it at least. Start pulling on the woolskin and it pulls the stitches out as you pull it off. If the woolskin is weak and tears, you still can get the bottom thread and pull that. I took him 11 minutes total to skin the stitches and pull the wool off. BTW, this also works for handsewn things too. Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
Contributing Member rdb Posted December 16, 2007 Contributing Member Report Posted December 16, 2007 Common Sense wins again. Great tip Bruce. Quote Web page Facebook
gtwister09 Posted December 17, 2007 Report Posted December 17, 2007 Bruce, WOW! This was one of the first things that I observed in removing stitches for skirts. Every time that I think that something is common sense I am reminded that even the simplest of things are overlooked if they aren't taught to someone. Once again a great reason for sharing this information before it is lost forever. Regards, Ben Quote
Moderator Art Posted December 17, 2007 Moderator Report Posted December 17, 2007 Hi Bruce, Another little tip, after you rip them apart, try using one of those big gummy rubber sticks like I use to clean the belts on my belt grinder to rub out the stitches. It works. Art I have had a running email deal with a guy today who is relining some skirts. Fairly common repair, and it started out to be a "Barge vs. rubber cement discussion". He was not relishing the 1-2 hours of picking stitches, and wanted to use the old stitch line. It is an older family handed down saddle, and sentimental as well as moderate collectible value. If you use a seam ripper, flat knife, or anything else between the sheepskin and the leather, it cuts the stitches, and never fails, the lock is buried in the skirt. You have to take each stitch out one at a time. They are old, they are hard, they don't want to come out. You cheer when you can pull a tag and get 3-4 stitches at once. . About 10 years ago, an older maker took pity on a younger guy and shared this tip. Since my pal who has done this sort of work for longer than me hadn't heard it, he shamed me into passing it along. Before you do anything on the wool side, take a stitch groover on the top side and run it over the stitches. One with the loop blade like Osborne's compass style groover works best. Running it over the stitches cuts and removes the top stitch, or severely weakens it at least. Start pulling on the woolskin and it pulls the stitches out as you pull it off. If the woolskin is weak and tears, you still can get the bottom thread and pull that. I took him 11 minutes total to skin the stitches and pull the wool off. BTW, this also works for handsewn things too. Quote For heaven's sakes pilgrim, make yourself a strop!
Elton Joorisity Posted December 17, 2007 Report Posted December 17, 2007 Another tool that works great(if you have one and I happen to have two) is a patent leather tool( freehand stitch groover made by Osbornes and Gomph) Jeremiah Watt also makes them. It is a breeze to knock the tops off the stitches then pull things apart. Usually not much picking left to do. Quote "If you see your stirrups slap together above the saddle horn, you're probably bucked off" Dave Stamey, The Bronc Ballet
Members mulefool Posted December 18, 2007 Members Report Posted December 18, 2007 Well, Good Grief, I've been pulling those things out with tweezers for the last 25 years. Now I guess I won't get to charge extra to use the old stitch line. Quote www.horseandmulegear.com
Members Bar C Leather Posted July 18, 2010 Members Report Posted July 18, 2010 LMAO!! Thanks guys! I'm glad I'm not the only one who thoroughly enjoys stitch picking!! My farrier plays polo and wreaks havoc on tack.... LOTS of sweat and NO cleaning. Always brings the dirty hard sweaty leather with stitches to match to me. Unfortunately most English tack has no stitch groove but at least most repairs are small areas!! I have a saddle awaiting relining in my shop and was dreading that chore so thanks for the tip!! Quote
