Members IH460 Posted December 20, 2024 Members Report Posted December 20, 2024 How are you guys finishing up a stitches on your Needle and Awl machines? I prefer to backstitch on presser foot machines, cut, melt and press smooth (Poly/Nylon thread) Linen projects in Needle and awl don't offer the option to melt and backstitch is not an option for any thread type. To current, I'm pulling a little longer than average at end, snipping and back stitching with harness needle by hand but wondering if there's a trick in the book I'm unaware of. Quote
Members Cumberland Highpower Posted December 20, 2024 Members Report Posted December 20, 2024 (edited) That's too much work IH460. You pretty much have 3 options on linen: 1) just cut it off where the stitch ends with a razor blade or fine tip clippers 2) When you come to the end of your work, make a stitch to the right or left and then a stitch back where you came from. (creating a small J pattern in your stitching. Thats' the most common way to end a long stitch on a Hook/Awl machine. 3) lift the presser foot and fudge/pull your work back one stitch and then make another stitch as close as you can to your existing stitching.. That's the same as reversing a stitch on a threaded needle machine. The wax on your thread will help lock it in place over time. Edited December 20, 2024 by Cumberland Highpower Quote
Members IH460 Posted December 20, 2024 Author Members Report Posted December 20, 2024 5 minutes ago, Cumberland Highpower said: That's too much work IH460. You pretty much have 3 options on linen: 1) just cut it off where the stitch ends with a razor blade or fine tip clippers 2) When you come to the end of your work, make a stitch to the right or left and then a stitch back where you came from. (creating a small J pattern in your stitching. Thats' the most common way to end a long stitch on a Hook/Awl machine. 3) lift the presser foot and fudge/pull your work back one stitch and then make another stitch as close as you can to your existing stitching.. That's the same as reversing a stitch on a threaded needle machine. The wax on your thread will help lock it in place over time. Thank you! For holsters/sheaths the J pattern is no trouble and sounds like the best solution. For belts and other items that offer no real estate for a J pattern or close stitch to existing it sounds like just cutting off close will be the way to go. Any harm in lightly tucking in loose end with a blunt awl on top side of work? Quote
