ffjdh Report post Posted 6 hours ago I’m having some difficulty with a project. I have a piece of English Bridle that I stamped. I scrubbed the stamped areas down with rubbing alcohol and a qtip, then painted it with slight thinned angels paint. I’ve painted vegtan many times and never had an issue with the paint. I had a little bit of over paint and started to clean it up with a dental pick about ann hour later and noticed the paint didn’t adhere to the bridle very well and could peel up. I let it sit for another 8 plus hours to see if it just took longer to set and it still comes up easily. What process works for you guys to paint bridle? Quote Share this post Link to post Share on other sites
DieselTech Report post Posted 6 hours ago There might be too much oils & waxes in the bridle leather for the paint to adhere. You might need to use acetone on the letter areas to be painted. Take a piece of scrap bridle leather & stamp it, then rough & clean the area with acetone & let dry for a day then paint your letters/leather. Might need to use a solvent base paint to, I am not sure. But curious to see what the answer is. Quote Share this post Link to post Share on other sites
dikman Report post Posted 28 minutes ago I would think if the leather has been treated with oils/waxes (as DT suggested) then you're going to have a very hard time trying to get any paint to stick. Oils and waxes are notorious for repelling anything and wax in particular is extremely difficult to remove completely. Quote Share this post Link to post Share on other sites
