Members Cumberland Highpower Posted 3 hours ago Members Report Posted 3 hours ago I've got another needle system question today. I've agreed to purchase a machine that uses a DBx1 or 16x231 needle system. I've not owned a machine as yet that's specd. for these needles. Are they in any way compatible with the 134/5 needles? Machine is a Seiko Te6 Quote
kgg Posted 3 hours ago Report Posted 3 hours ago (edited) 12 minutes ago, Cumberland Highpower said: I've got another needle system question today. Here is some info. A lot is going to depend on the bore of the needle bar. What machine are they for? kgg Edited 3 hours ago by kgg Quote
Members Constabulary Posted 2 hours ago Members Report Posted 2 hours ago The Seiko TE-6 head section is pretty much the same as on my former Singer 34K5 (Singer 16 type so to say) which I have restore and later it had an accident and I had to replace the needle bar. I have used a Singer 17 needle bar which is the same as the Seiko and it worked. I used 135x17 needles though the shank is thicker as on Singer 16 needles - it just worked with the new needle bar back then. Just my experience but I no longer have this machine I have replaced it with the Singer 51w. I would simply try a different needle and adjust the needle bar height. Just hand crank it and see what it does. https://leatherworker.net/forum/topic/66729-singer-needle-bar-i-could-use-some-help/#findComment-434368 Quote
