Members JDC Posted March 1 Members Report Posted March 1 Hey everyone! I'm new here and need help. I recently bought an old very well used pfaff 145 from where I work. They were selling it because it was dropping stitches when they were making piping, which was the only job it did for years. It worked fine at lower speeds and with normal thread, but they were asking it to go at essentially warp speed using monofilament thread so it didn't fill the need anymore. I got it home and went about figuring out how to use it. I found that the monofilament had worn some parts pretty badly in a few places and it was fraying and breaking thread in those places. I sanded the worst bits smooth enough that it wasn't too bad but I couldn't possibly keep up to the speed they had it set to, so I changed the pulley ratio. Now enter the problem: something seems to be loose in there somewhere. I can hear it rattling at a couple of specific spots and the hand wheel definitely gets tighter when the rattle occurs. Some times it even stops me hand turning it. Once it even stopped the motor. I've had all the inspection covers off and don't see a source of the rattle or binding. I remove the machine from the table and set it on its end to hand cycle it to see if I can see something at a different angle but then there's no rattle. Does anyone have any experience with these or similar machines doing something like this? Quote
Members shoepatcher Posted March 17 Members Report Posted March 17 thread size and needle you are using? glenn Quote
Members JDC Posted Friday at 06:05 PM Author Members Report Posted Friday at 06:05 PM Doesn't matter, it binds with no thread in it. Quote
Members fibersport Posted Saturday at 12:22 PM Members Report Posted Saturday at 12:22 PM I had a 145 that had sat for years. Initially it had sort of a hard spot as you rotated the handwheel that got better once I reset the timing. I now have a 545 that ran very smooth but once I reset the timing in it, it ran even smoother. Granted it sounds that yours has some miles on it but it might be worthwhile to check the gear backlash and overall timing of it. Quote
Members Tigweldor Posted Saturday at 10:57 PM Members Report Posted Saturday at 10:57 PM (edited) Usually when the old Pfaffs have a "hard spot" - it is from old oil having solidified in/on the intended oiling surfaces. The best thing to do is to get some kerosine (grill starter) and apply that to all of the oiling points and then run the machine - while applying more and more grill starter. A can of carb cleaner with the long skinny plastic tube that you can inserted into the spray nozzle is my favorite. The aim is to dissolve old caked on oil deposits - some can be quite resistant to dissolving/removal. After a while the machine will most often smoothen out - then apply good white sewing machine oil. Here is the instruction book for the Pfaff 145 : https://www.bedienungsanleitu.ng/pfaff/145/anleitung?p=5 Edited Saturday at 11:07 PM by Tigweldor Quote
