Members barcsaddlery Posted March 13, 2025 Members Report Posted March 13, 2025 I have acquired an older Claes 8346 - I believe it might be a 10 because the bobbins are TINY. I'm just curious if it is possible to swap out the cylinder/arm to essentially upgrade the machine to a 20 or 30. Thanks! Quote
AlZilla Posted March 14, 2025 Report Posted March 14, 2025 @barcsaddlery, I split you out into a new topic. You were just going to get lost at the bottom of a 6 year old thread, Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Members Constabulary Posted March 14, 2025 Members Report Posted March 14, 2025 check the parts list and try to figure what parts are needed but I honestly doubt you can do that and even if it was possible the parts will be crazy expensive. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members shoepatcher Posted March 14, 2025 Members Report Posted March 14, 2025 Might be able to but will be expensive. Parts list will show parts that can be switched. Both 10 and 20 use needle system 81. glenn Just now, shoepatcher said: Might be able to but will be expensive. Parts list will show parts that can be switched. Both 10 and 20 use needle system 81. 20 bobbin holds 15 yards of #69thread, 10 bobbin holds 12 or 13 yards of #69 thread not much difference glenn Quote
Members Tigweldor Posted April 4, 2025 Members Report Posted April 4, 2025 Try asking the manufacturer - they still do make the 8346 model. https://claes-naehmaschinen.de/en/services-and-products/sewing-machines.html Quote
