Members Moishe Posted April 10 Members Report Posted April 10 Hi Guys I need a help! my Pfaff 545 stop sewing the hook is spinning and not catching the thread! Any idea what is wrong with it? How to fix it? Quote
Northmount Posted April 10 Report Posted April 10 1 hour ago, Moishe said: my Pfaff 545 stop sewing the hook is spinning and not catching the thread! Moved your post to Leather Sewing Machines. More likely to get an answer here. Can you provide more information to help solve your problem? Have you checked your needle for damage, is it threaded correctly? Was it working fine then suddenly quit, any noise, did it jam or lock up? Quote
Members shoepatcher Posted Friday at 08:30 PM Members Report Posted Friday at 08:30 PM Safety clutch out? glenn Quote
Members Moishe Posted 20 hours ago Author Members Report Posted 20 hours ago On 4/10/2025 at 5:35 PM, Northmount said: Moved your post to Leather Sewing Machines. More likely to get an answer here. Can you provide more information to help solve your problem? Have you checked your needle for damage, is it threaded correctly? Was it working fine then suddenly quit, any noise, did it jam or lock up? It was working perfectly! And sadly started no make loops Quote
Members Moishe Posted 20 hours ago Author Members Report Posted 20 hours ago Hi Guys I need a help! my Pfaff 545 stop sewing the hook is spinning and not catching the thread! Any idea what is wrong with it? How to fix it? Quote
Members Moishe Posted 20 hours ago Author Members Report Posted 20 hours ago On 4/11/2025 at 4:30 PM, shoepatcher said: Safety clutch out? glenn No everything fine Quote
Members nejcek74 Posted 15 hours ago Members Report Posted 15 hours ago 1) Check first the obvious part as it is written above: - is threading right, is thread moving through the needle, check threading through every single part, i.e. tensions disks, check spring assembly etc. - check the needle, is it bent or damaged 2) is the upper thread going around the hook? 3) check the needle position to hook and hook timing, I suggest using the old adjustment manual for Pfaff 1245 (the successor of 545), needle and hook timing is described in point 5, but I suggest going through everything: Pfaff 1245 Adjustment 89_09.pdf Quote
Northmount Posted 6 hours ago Report Posted 6 hours ago 13 hours ago, Moishe said: Hi Guys I need a help! my Pfaff 545 stop sewing the hook is spinning and not catching the thread! Any idea what is wrong with it? How to fix it? I merged this post back into your existing thread. There is no need to start a new thread with the same question. All it does is cause more clutter on the forum. If you continue to behave like this, you will be put under moderation. All your posts would then require moderator's approval before they can be seen by members. Quote
