AEBL Posted May 11 Report Posted May 11 (edited) I made a bag (sort of a tote bag), trying to learn how to use my new sewing machine (Consew 206RB-3). It came with lots of B69 thread. I'm used to hand sewing with 0.6 mm tiger thread and this stuff seems like spider silk by comparison. Is it thick enough for reliable handle attachment? The sewn tab is 2 inches long. Edited May 11 by AEBL added sewing machine type Quote
Members Tigweldor Posted May 11 Members Report Posted May 11 Naturally that depends upon how much weight you plan to tote around in your bag. You can always strengthen the handle attachment stitching by making a box X stitch. Also it matters on how the rest of the bag is stitched - no use having a monstrous handle if the stitches fail at the bottom of the bag and it falls apart there. Greetings Hans Quote
AEBL Posted May 11 Author Report Posted May 11 Very true! But it doesn't seem like B69 was a poor choice, from what I gather? This is a prototype, I already warned the wife about it ... Quote
AlZilla Posted May 11 Report Posted May 11 Plenty of handbags are made on domestic machines with V69 or less. Unless it's a bowling ball bag, she'll be fine. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
kgg Posted May 11 Report Posted May 11 On 5/11/2025 at 12:24 AM, AEBL said: I'm used to hand sewing with 0.6 mm tiger thread and this stuff seems like spider silk by comparison. Is it thick enough for reliable handle attachment? Expand I guess it depends on how large the bag is and how much stuff it will be loaded with as well as your stitch length. It comes to a point where if your stitches per inch are to small the seam will act like a perforated paper tear off strip like you see with a cheque book. As a comparison the V69 you used to attach the handle has a breaking strength of 11 lbs and is about 0.012 thick versus the 6mm thread you are use to having a diameter of 6mm and a breaking strength of about 50+ lbs. If you want to use thinner thread as V69 is really in my opinion a domestic size thread. Typically the domestic sewers refer to that size, V69, as heavy duty as it is the largest size most domestic sewing machines can take. I would move up to V92 with a breaking strength of 14.5 lbs and probably a stitch length of 6 stitches per inch. As a note: i) B69 is basically the same as V69, Tex 70, M40, Tkt 40, D236/3 just a different designation standards. In North America the two typical standard ways of referring to a thread size is either by the US designation, " V " and in Canada the metric " M " and the US " V " designation. ii) The Consew 206RB-3 uses system 135 x 17 x (needle size) needles for fabric and 135 x 16 x (needle size) needles for leather. When sewing leather use the 135 x 16 x (needle size) appropriate for the size of thread. Here is a good cross reference chart for thread size and the corresponding needle size that should be used. ( https://www.tolindsewmach.com/thread-chart.html ) kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
AEBL Posted May 11 Author Report Posted May 11 (edited) Thanks for the info! (and CowboyBob's chart is great) Edited May 11 by AEBL Quote
AlZilla Posted May 11 Report Posted May 11 Here's a dissertation on seam strength: https://www.sailrite.com/How-to-Sew-Webbing-Loops Sailrite says "Stitches Per Inch x Breaking Strength x 1.5" = Seam Strength Per Inch I think your wife's handbag is going to hold up. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
kgg Posted May 11 Report Posted May 11 On 5/11/2025 at 3:36 PM, AlZilla said: Here's a dissertation on seam strength: https://www.sailrite.com/How-to-Sew-Webbing-Loops Sailrite says "Stitches Per Inch x Breaking Strength x 1.5" = Seam Strength Per Inch Expand This formula can very misleading as it was develop mostly for fabric and indicates that by increasing the number of stitches per inch increases the seam strength it leaves out the practical factor before you damage / weaken the material, fabric or leather. As a note the strength factor would be 1.7 if you were using a Chainstitch machine. Using the formula in that article for Lockstitch machines: i) 6 stitches per inch x V92 having a breaking strength of 14.5 lbs x the strength factor= 130 lbs / inch ii) 20 stitches per inch x V92 having a breaking strength of 14.5 lbs x the strength factor= 435 lbs / inch The stitches per inch is stitch density and for leather it is recommend the stitch density should not be more then 3 to 4 per cm which converts to 6.35 - 8.46 stitches per inch. The reference article for this is Schmetz, Sewing Focus Technical Sewing Information -- Section 3.3 ( https://www.schmetz.com/mm/media/zh/web/7_tochtergesellschaften/bilder_18/schmetz/pdfs_4/sewing_focus/SewingFocus_20_3075-22_Lederbekleidung_D.pdf ) kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
AlZilla Posted May 11 Report Posted May 11 As a practical matter, I believe the strap is going to stay safely on the lady's handbag. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
AEBL Posted May 12 Author Report Posted May 12 She'll be happy about her bag being safe-ish for lugging all of the stuff she lugs around, for sure. I'm seeing how much of an engineering problem this is ... and I'm liking it more. Makes me want to set up some stitch samples and a set of weights and take some failure data. I'm sure it also depends on tannage and thickness somewhat. Very neat. Quote
