Ambassador abn Posted July 3, 2007 Ambassador Report Posted July 3, 2007 Thanks, Kate. Let us know how the color holds up in the sun. BTW, I've been using these dyes for a few weeks now, and I have a couple of observations: The colors are not quite as vivid as those of spirit dyes. In my experience, it's best to apply these when the leather is completely dry, since wet leather seemed to act as a bit of a resist. Although they won't rub off when dry, they are a bit sensitive when wet -- applying a coat of Lexol and wiping off when still wet will remove some color. Same goes for Satin Shene. So you have to be gentle when conditioning and finishing. On a related note, I actually prefer the All-In-One Stain and Finish over the straight leather dye. It goes on easier, provides a bit of antique contrast, and leaves a really nice mellow finish. Plus, the colors are as vivid as spirit dyes. I'm finishing up a couple of projects using All-In-One, and I'll be sure to post some pics soon. -Alex Quote
Ambassador freak Posted July 10, 2007 Author Ambassador Report Posted July 10, 2007 I just tried two diff colors of the Antique Gels. Ummm, ,,, I don't like them. I don't like them at all. The Tan was Ok at best for me. I did 2 phone cases. Both of them i used the eco flow Ranger Tan. Then on one i used Fiebing"s Antque Tan paste and on the other i used the eco flow Gel Antique Tan. With the Fiebing the over all color changed very little. It did what it should and for the most part darken the tooled part only The Eco Flo on the other hand darkened the case as a whole. I aslo tried the Eco Flow Mahogany Antique over Ranger Tan. Hoping i would get a lot of lift if i just wiped it on and right off. NO !!! That didn't happen. It is now a nice dark Mahogany. Now for the plus. The Eco Flow Coal Black dye: it's as nice of a black as i've seen. Anyone that uses the Fiebing Black Oil dye might want to try it. That's what i've always used for black. Two coats and it's freakin black. The same goes for the Eco Flow Coal Black. Quote It takes more then one freak to have a true freakshow. So take a seat , the show is about to start. Check out the freakSHOW
Contributing Member wolvenstien Posted July 11, 2007 Contributing Member Report Posted July 11, 2007 no "chalking" of the eco flo black lik ethe pro oil does? Quote "The miracle is not how two adults can create a child, the phenomenon is how quickly a child can create two adults." -- VYBE Her: Hit Me Him: Do you want me to use the knife? Her: No, When you hit with a knife, that's STABBING!
Ambassador abn Posted July 12, 2007 Ambassador Report Posted July 12, 2007 W, I haven't tried the black dye yet, but I used the next darkest dye (Dark Coco Brown), and rub-off was virtually non-existent when dry. Alex Quote
Members whinewine Posted July 12, 2007 Members Report Posted July 12, 2007 I'm working on a sporran that my son wants to be in black. We tried a scrap of eco coal black last night & this morning with 2 coats is was VERY black- and almost NO CROCKING. I ordered a quart & will pick up Saturday. I'm (so far, anyway) impressed but I won't know until I dye the whole sporran to determine how well the dye saturates. BTW, eco coal black is the only eco dye that tandy recommends NOT be sprayed. Quote
Members CitizenKate Posted July 18, 2007 Members Report Posted July 18, 2007 I'm still testing the antique/highlighter, still no formal opinion... The dyes... interesting. I've had some color samples (with no sealer or other finish) sitting in one of my south-facing windows for over a week, where they are getting several hours of direct sunlight almost every day. So far, I don't see any signs of fading. They don't seem to be exhibiting the usual signs of "bleaching" either - wonder if the color is having an effect on that. I took a photo of them before placing them in the windowsill... I'll take another photo in another week or two so we have a reference point to compare, and post them so you all can see. Kate Quote
Members whinewine Posted July 23, 2007 Members Report Posted July 23, 2007 I'm working on a sporran that my son wants to be in black. We tried a scrap of eco coal black last night & this morning with 2 coats is was VERY black- and almost NO CROCKING. I ordered a quart & will pick up Saturday. I'm (so far, anyway) impressed but I won't know until I dye the whole sporran to determine how well the dye saturates. BTW, eco coal black is the only eco dye that tandy recommends NOT be sprayed. Here are my test results with eco coal black dye: I dyed a test sporran in eco black over the weekend. I used 2 coats, both sides, using a dauber, and I didn't use any blue or dark brown basecoat like you'd have to do first if using spirit dye. Overall, black coverage is pretty good on the grain side (could use a 3rd coat, but still, pretty decent black coverage), but the flesh side seems to really suck up a lot of dye and the color is more blue & mottled than it is a true black, even after 2 coats. There IS some crocking (rub-off), but certainly it's a whole lot less than with using spirit dye. Good buffing removes most of it , and hopefully the rest can be sealed appropriately with neatlac or supershene so that it doesn't crock. Sealing is a must: since it is water-based, even a wet or damp finger will cause the dye to come off on it. I also tried to spray the eco black to see what would happen (even though NOT recommended by Tandy). I used a preval sprayer. It will spray, but it seems that the amount of pigment in it causes the preval to spit globules of black all over the place (not all the time, but throughout the spray test), rather than give a nice, relatively even coverage. Perhaps an adjustable spray gun would give a better, more even coverage than the preval does. If anyone has different (or the same) results, I think others would like to hear about your results. Overall, I'm still pretty well impressed. I just wonder if the black would be as black if one used a dark brown or dark blue basecoat first (either eco or spirit dye) & then applied just one coat of eco black over top??? Quote
Members whinewine Posted July 24, 2007 Members Report Posted July 24, 2007 Here are my test results with eco coal black dye:I dyed a test sporran in eco black over the weekend. I used 2 coats, both sides, using a dauber, and I didn't use any blue or dark brown basecoat like you'd have to do first if using spirit dye. Overall, black coverage is pretty good on the grain side (could use a 3rd coat, but still, pretty decent black coverage), but the flesh side seems to really suck up a lot of dye and the color is more blue & mottled than it is a true black, even after 2 coats. There IS some crocking (rub-off), but certainly it's a whole lot less than with using spirit dye. Good buffing removes most of it , and hopefully the rest can be sealed appropriately with neatlac or supershene so that it doesn't crock. Sealing is a must: since it is water-based, even a wet or damp finger will cause the dye to come off on it. I also tried to spray the eco black to see what would happen (even though NOT recommended by Tandy). I used a preval sprayer. It will spray, but it seems that the amount of pigment in it causes the preval to spit globules of black all over the place (not all the time, but throughout the spray test), rather than give a nice, relatively even coverage. Perhaps an adjustable spray gun would give a better, more even coverage than the preval does. If anyone has different (or the same) results, I think others would like to hear about your results. Overall, I'm still pretty well impressed. I just wonder if the black would be as black if one used a dark brown or dark blue basecoat first (either eco or spirit dye) & then applied just one coat of eco black over top??? Update: My son came here last night & dyed his sporran eco black- two nice coats (with a dauber) for good even coverage, and left the backs undyed. This morning I sprayed the backs of each piece with spirit mahogany dye, let dry & used a dauber to apply one coat of eco black. While there is just an ever-so-slight brownish cast, the coverage is significantly more even than with the daubered two coats of black that I used on the flesh sides of mine (I also applied a third daubered coat of eco black to the flesh sides of mine to blacken-up the mottled blue, but the pieces with the sprayed spirit dye + 1 coat eco black with a dauber are much more even than even the 3 heavy coats of eco black). Quote
Members Rayban Posted October 23, 2007 Members Report Posted October 23, 2007 I hear that Tandy will be coming out with some bio-degradable leather real soon to go with their eco-friendly dyes..... Quote Raybanwww.rgleather.net
