Hi all,
I'm sure this is probably a common issue with a simple answer, but how do I stop the dye from staining my thread as I stitch? Am I missing a step in setting the dye (like Rit for fabric)?
For reference, current shenanigans: 6oz econo veg tan, Angelus oxblood dye, Ritza 1.2mm beige thread.
Thanks,
AZR
Oh it happens.  The method that works best for me is to make sure to let the dye dry for longer than you would think.  A full day or so.  Then, if hand stitching, I will use about an extra 2 feet of thread.  The extra thread will pick up most of the dye when sending the needles through the holes, then you can cut off the excess when finished stitching.  It isn't foolproof, but does minimize the dye on the stitching in the holes.  Good luck.
In God's Grace,
Pastor Bob
"While we were yet sinners, Christ died for us." - Romans 5:8
www.PastorBobLeather.com
YouTube Channel
Also, buff the leather after the dye has dried.  That helps alleviate much of the rub-off.
Another route to take would be to chisel your stitchline after the dye job, instead of before.  That also helps prevent thread staining.  THis method does have the potential of showing raw leather inside the stitch line, however.  There are pros and cons both ways.
