Members Constabulary Posted July 16, 2025 Members Report Posted July 16, 2025 Here are some pictures of my 8346-30. BTW when you look at the data plate the number below "BAUJAHR" is the year when it was made. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Constabulary Posted July 16, 2025 Members Report Posted July 16, 2025 some more Hope the pics help setting up yours. Mine still has thee original clutch motor but your seem to have a modern servo motor alreday. If you need more detailed pictures let me know. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members shoepatcher Posted July 16, 2025 Members Report Posted July 16, 2025 You have lots of parts. Need a servo motor for it. Does the engraved line on the front of the base say 8345-6 or 8346-6? It has an early Claes cast iron stand almost like the Pfaff Metro Spezial that was a Claes in everything but name. Claes sold machines to Pfaff that Pfaff out their name on it. What questions do you have on the machine? glenn Quote
Members ya2daup Posted July 19, 2025 Author Members Report Posted July 19, 2025 On 7/15/2025 at 1:33 PM, friquant said: Forgot that you have two hand wheels! Or one giant handwheel and two motor pulleys (one on the motor, one one the patcher). This is going to mess up my terminology notes for sure 🤷♂️ From your video, I'm not sure if that lateral motion is a problem, a feature, or neither. Is there anything along the main shaft that looks like it's intended to impede this lateral motion? Ha! Sorry about that, I think you got the picture but I'm referring to the motor pulley on the patcher. I've spent some time looking it over, along with the engineering diagram I have (in German) It appears that everything on that shaft is pinned and has a sew screw so I don't see any opportunity for adjustment. I did pop the pin on the aformentioned pulley and tapped it in further which does take up the slop but without the pin that's not a long term solution. At this point I don't believe there is any solution within the machines available adjustments but the "clunking" is going to get annoying. So I think I'm going to pull off the pulley and insert a couple nylon washers. Not so much that it's tight and binding but enough so that it has minimal travel On 7/16/2025 at 12:48 AM, Constabulary said: Here are some pictures of my 8346-30. BTW when you look at the data plate the number below "BAUJAHR" is the year when it was made. Thank you for all the pictures! It really helped identify some of that parts and what I should be considering when finishing the setup. I went ahead and ordered a servo motor and speed reducer. I'll have to make a couple custom mounts but for the most part I'm happy with the progress and plan. I looked at the plate again, it was made in '81 On 7/16/2025 at 9:16 AM, shoepatcher said: You have lots of parts. Need a servo motor for it. Does the engraved line on the front of the base say 8345-6 or 8346-6? It has an early Claes cast iron stand almost like the Pfaff Metro Spezial that was a Claes in everything but name. Claes sold machines to Pfaff that Pfaff out their name on it. What questions do you have on the machine? glenn I'm not sure what engraving on the base you're referring to. The serial number plate on the machine says 8346/30. Now that it's sewing well and I have some more background info I went ahead and ordered a servo and a speed reducer. Other than my concern about the main shaft's horizontal movement (and the associated slop in the hand crank's spider gear) I think we're on the right track! Quote
Contributing Member friquant Posted July 19, 2025 Contributing Member Report Posted July 19, 2025 57 minutes ago, ya2daup said: So I think I'm going to pull off the pulley and insert a couple nylon washers. Not so much that it's tight and binding but enough so that it has minimal travel That sounds good to me Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
Members ya2daup Posted July 29, 2025 Author Members Report Posted July 29, 2025 A couple weeks later and she's pretty much squared away. A thin plastic washer in between the motor side pulley and the casing got rid of the clunk I was complaining about earlier. There's still a lot of play in the hand crank but I'm not going to worry about it. I still need to finish up the bobbin winder and tall spool placement. The O-ring for the bobbin winder didn't come with the machine and I can't justify paying $25 for the "bobbin winder rubber" from Landis. BTW, a new shuttle costs $400!?!?! I have two, fingers crossed I never have to pay for a new one! I ordered a new servo motor with needle positioning sensor for my Consew and moved its servo motor over to this machine along with a 3:1 speed reducer. I had to make a couple custom mounts and platforms but enjoyed working through the process. While doing some testing, the machine was running about 32 SPM which is exactly what I was hoping for. I did get some belt slippage when not giving it a running start on some thick leather. I'm wondering if a rubber v-belt would do better than this adjustable fiber chain belt that came with the machine. It was very convenient for setting everything up but it seems to be more "slippery" than what a v-belt would be. Eventually I may get some low profile wheels but for now I think it'll just live on the floor. Thanks for the advice and feedback! Quote
Contributing Member friquant Posted July 29, 2025 Contributing Member Report Posted July 29, 2025 The visual of the dual belts running up the right side is picturesque! Congrats on getting it up and running 🌻 Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
