Contributing Member fredk Posted July 15 Contributing Member Report Posted July 15 10 hours ago, Stetson912 said: I had used multiple layers. Both of these were made from laminated 4-5 oz leather to make the front and back panels. The front panel requires additional work obviously. I cut the window out, trimmed and skived the plug, skived the areas of the panel from the stitch lines to the edges, glued the plug in place, glued the caiman over the plug, then glued the window over everything and stitched it together. Not as simple a construction as I thought Well done Quote Al speling misteaks aer all mi own werk..
Members Stetson912 Posted July 15 Author Members Report Posted July 15 5 minutes ago, fredk said: Not as simple a construction as I thought Well done You can use 8 oz for the panel then cut v the window from 4 oz and glue it on top. The skiving of the window panel reduces the thickness on the "wings" making it a bit cleaner and I think more comfortable. You need the 8 oz for the holster structure. I jmloke using the 2 layers of 4 oz laminated because it gives me a liner and is a bit stronger. You could take your 8 oz and make the front panel rough out and then the window on top, but then you would have to line the back panel or have a half lined holster hahaha Quote
