Members P56 Posted August 9, 2025 Members Report Posted August 9, 2025 Hello, I have already searched this forum and none of what I found helped, I also posted this here under sewing if one needs to be deleted feel free. I am running a JUKI 1541s, when I insert a new bobbin and rotate the hand wheel the needle will pick up the bobbin thread. Once I start sewing it will no longer pick up the bobbin thread, just leaves a nice row of empty holes and the thread in the needle is frayed like crazy. When I take the plate off so I can see the hook and turn the hand wheel it seems to work fine, the hook picks up the thread every time. I have re-threaded the machine, changed the needle (135x16 size 23), lubricated the machine including the bobbin and hook, checked the hook timing and spacing, the hook is turning so its not clutch issue. The needle is in the correct way, I am holding the thread for the first few stitches, I have played with both upper and lower tension. Any ideas? So frustrated!!!!! Could it be the needle is to big? I am currently running Mandala bonded Nylon #138 with a #23 needle. I have ordered smaller needles, but could that be the issue? Quote
Moderator Wizcrafts Posted August 9, 2025 Moderator Report Posted August 9, 2025 A #23 needle is the right size for #138 thread on the top and bottom. Look closely at the leather under the needle to see if it is lifting with the needle as it ascends. This almost always causes skipped stitches. If it is lifting, add more foot pressure. Inserting the needle backwards has the same effect. Make sure the rib side is on the left and the scarf side faces due-right. If the check spring is set wrong for the work, it can cause skipped stitches. The bottom stopper should halt the downward motion of the check spring as or just after the tip of the needle enters the top of the work. The longest it should allow downward motion would be as the eye shows just under the bottom layer. The other settings are spring tension and slack adjustment, via a set screw inside a curved slot. Try changing the position of that screw. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
AlZilla Posted August 9, 2025 Report Posted August 9, 2025 This post contains @Wizcrafts recent dissertation on all things Check Spring. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Members P56 Posted August 10, 2025 Author Members Report Posted August 10, 2025 Thanks for the info!! The foot pressure, and check spring I did not check. Quote
Members Constabulary Posted August 10, 2025 Members Report Posted August 10, 2025 I´d check the needle - hook timing / needle bar height. My guess is the NB is set a little to high. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
